New switch, no start.
RyanGLT
Year and Model: '07 XC90 V8 AWD
Post by RyanGLT »
I know...talk about an annoying problem. This is why I daily drove a 1965 Corvair for 4-5 years...when it broke I knew how to fix it...
'07 XC90 V8 AWD
holler1
Year and Model:
Post by holler1 »
Here's a wiring diagram that might be helpful. Look at the last page.
volvo v70 starter diagram bosch.pdf
(127.36 KiB) Downloaded 153 times
1998 Volvo V70 AWD 165000-R muffler, HD endlinks, boost gauge
2008 Ford Fusion AWD 107000
2000 Ford Ranger 4wd 172000
1991 Toyota Camry 160000#1
Previous: 1982 Volvo DL (240) 160000
1998 Tacoma, Fords (6), Dodge, Montero,
GTO, Sunbeam Alpine, VW Dasher
holler1
Year and Model:
Post by holler1 »
RyanGLT wrote:I know...talk about an annoying problem. This is why I daily drove a 1965 Corvair for 4-5 years...when it broke I knew how to fix it...
I have a 91 Camry with 160k miles as a backup car. it's worth nothing, but it has never failed to start and run.
RyanGLT
Post by RyanGLT »
Anyone know where the alarm relay is actually located on the car?
'07 XC90 V8 AWD
jblackburn
Year and Model: 1998 S70 T5
Has thanked: 9 times
Been thanked: 20 times
Post by jblackburn »
https://www.matthewsvolvosite.com/forums ... hp?id=3355
Open that file, and scroll down to page 4. It is the big 2-space relay on the 2nd row up of the relay panel under your dashboard, labeled "O".
'98 S70 T5
2016 Chevy Cruze Premier
RyanGLT
Post by RyanGLT »
hey Thanks. near as I can tell, that relay is dead. it is the only component I can see that I'm bypassing by sending positive voltage from the battery to the service connector.
and of COURSE it has to be an 85 dollar part. :rolls eyes:
'07 XC90 V8 AWD
jblackburn
Meh. Don't pay good money for a new one. Volvo sells a bypass relay, or you can get one from a junk car or someone parting one out on the site here or in the for sale section of Volvospeed. Look around, see what you can find.
'98 S70 T5
jblackburn
Ozark Lee wrote:You can bypass the entire alarm system by removing Relay 210 / 211; it is located high on the firewall, inside the car, directly below where the fuse box is. After you remove the relay the car will not start until you add a jumper wire between the socket positions associated with pins 50E and 50F on the 210 side of the relay. If you decide to permanently disable the alarm Volvo sells a dummy 210 relay that has the jumper wire built into it."
Remove the relay and your (existing) jumper wire and try that^^^
'98 S70 T5
RyanGLT
Post by RyanGLT »
went outside to start the car this morning and my battery was dead.... :facepalm:
I hate the most that it all happened at once: ignition switch finally kicked the bucket, my battery finally died enough that it won't hold a decent charge, and ontop of it, my alarm relay shyte the bed.
All the week I have no money and only 12 days til I'm scheduled to take a 1500 mile trip (well, at least 720 one way)
'07 XC90 V8 AWD
RyanGLT
Post by RyanGLT »
Okay. This won't make sense.
I pulled the Alarm Relay out and jumpered it. no change.
Out of frustration I decided to take the ignition switch back out and see if the old one would make the car start.
It did.
So I put the new one on. It ALSO made the car start.
put it back in and tried the key and....
nothing.
So final synopsis?
Somehow the tumbler is ALMOST but not quite making it far enough to make the contacts touch. I can feel the spring in the ignition switch though, so it's getting REALLY close but maybe just not quite there.
in the meantime, my button is working nicely. LOL
'07 XC90 V8 AWD
