daytime lights
Build a Coolant Level Sensor for 2nd gen S40 & V50 Volvos
daytime lights
The Volvo 850 lights go out as soon as the ignition is switched off. Does this mean it is ok to leave headlight switch in on position all the time if you want daytime running lights but your version of Volvo 850 does not have that? I thought it might strain the battery if lights are going on while it is starting.
White850Turbo
- Year and Model:
No, you can leave it in the headlamps on position at all times. The car will automatically turn off all unnecessary accesories such as lights, air vents, and stereo when starting so as to utilize max power to start the car.
-Sean
1995 850 Turbo (Extensively Modded)
1998 S70 T5 (Almost Stock)
- 7824 Views
Last post by JRL
- 2288 Views
Last post by Liliflower
