Power steering fluid flush problem
t5ftw
Year and Model: 1999
Post by t5ftw »
I have 99 S70 T5. I had left over ATF. So, I tried flushing power steering fluid. I siphon out the reservoir and refilled. turned on the engine, turn the wheel from lock to lock a couple of times, and turned off the engine. Then, repeated the process 4-5 times. My manual says to use ATF for steering fluid. But when I looked at the fluid, it was brown like a old engine oil. After the flush, I can barely move the wheel. What did I do wrong? Is there a chance that I damage anything?
Jack Rock
Year and Model: 1998 V70R
Post by Jack Rock »
That brown oil used to be red, it's just that old and due for a change. I doubt you've damaged anything but it sounds like you have an air lock. Let the car idle for a while with the cap off, periodically and slowly turn the wheel lock to lock. If it's making a grinding noise you'll see tiny air bubbles coming up through the oil, otherwise known as cavitation. Take your time, I had the same thing happen to me.
1997 850 T5 (gave up at 324,000km)
1998 V70 R AWD (gave up at 296,000km)
1998 S70 T5 (total loss - in a parking lot!)
1999 V70XC
1975 VW beetle
1960 Empi Sportster Dune Buggy
confused_al
Year and Model: 1996 TLA wagon
Post by confused_al »
If your PS was using PS fluid previously, you dont want mix w/ ATF. As I recalled Volvo switched to use PS fluid somewhere in 1999/2000 model year due to different PS pumps were used (ZF pumps). Is your reservoir sits by itself or on top of PS pump? If yours is sits by itself, most likely you have a ZF pump.
96 850 Platinum Wagon
98 MB ML320
06 V70
95 850 GLT(RIP)
confused_al
I found pics for these two different pumps.
the one with reservoir on top:
ps pump 98.JPG (29.26 KiB) Viewed 3930 times
separate reservoir:
ps pump 2000.jpg (321 KiB) Viewed 3931 times
98 MB ML320
06 V70
95 850 GLT(RIP)
Year and Model: Many Volvos
Been thanked: 75 times
Post by Ozark Lee »
To confused_al's point. I inadvertently mixed power steering fluid and ATF in my wifes old Jeep and it turned into a frothy gelatinous goo. I never did drive it that way but 4 or 5 iterations of the drain the reservoir, refill, run the steering lock to lock a few times and repeat cleared the system and it worked fine.
My Volvo's all take "a quality ATF" - per the owners manual - but I have nothing newer than a '98. In reality I think either one is likely fine but don't mix them together.
t5ftw
Post by t5ftw »
My fluid reservoir does not look like those in pictures. Rather, I have something look like the one in the next picture. Does that mean ATF is still correct fluid but somehow previous owner used wrong fluid? I will probably let it idle for a while and if it gets worse, I will try flush more fluid out. Or maybe I should just flush with PS fluid? I will 'Never touch something that is working fine.
jblackburn
Year and Model: 1998 S70 T5
Has thanked: 9 times
Been thanked: 19 times
Post by jblackburn »
A '99 uses synthetic PS fluid not ATF.
You may have to remove the hose to the pump to flush out all the old junk out of there.
https://www.matthewsvolvosite.com/forums ... php?t=8644
'98 S70 T5
2016 Chevy Cruze Premier
t5ftw
Post by t5ftw »
I guess I made it really a bigger job.
I checked out local auto part stores like auto zone, advanced auto, O'riely, but none had any synthetic PS fluid. I see eeuroparts has it. Are the synthetic and non-synthetic fluids very different? Will it be ok to use non-synthetic temporarily?
jblackburn
If the VW dealer in town is open today, stop by and pick up 1-2 qts of the Pentosin power steering fluid.
Regular fluid would probably be better for it than ATF to get the flushing started anyway. I'm not sure how much the entire system holds.
'98 S70 T5
t5ftw
Post by t5ftw »
Good idea. They open until 2:00 pm, but in Roanoke.
