Hi 95 850 na 165K,
mechanic said sway bar link, passanger side broken. Is that easy to replace? I am a newbie mechanic.
Also read in an Ebay 850 listing of a 850 equipped Mega squirt. I am easy on the gas, my gas mileage is 20 in the city, 25 on the highway. Just replaced plugs and wires, next is dist. cap and rotor. Is that usual gas mileage?
Thanks in advance, I really like this site, especially for non-mechanics. Thanks Matthew and all of you.
Jack
sway bar link easy to repair, mega squirt ?
adventurer2112
- Year and Model: 95 850 na
- Been thanked: 7 times
IVIUSTANG
- Year and Model: 2006 XC70
- Been thanked: 4 times
Sway bar links are easy for anyone with a jack, requires two bolts to be removed. If you jack your car in the centre of the sub frame(so you lift both front tires) it should put even pressure on the sway bar so you can do it with one jack. Most recommend doing both end links, as a broken one can put excess pressure on the other side causing wear. It MAY be possible you need to have an extra jack to load either the spring or sway bar to line up the bolt holes, I have never needed to.
As for your fuel economy, 20/25 US MPG is in a typical range I would say.
- Jesse
- Jesse
1998 S70 T5 SE 290,000 KM sideswiped total loss(Sweet ride!)
2007 S60 2.5T loaded 63,000 KM SOLD!
2006 XC70 350,000 KM, 2" BadSwede lift kit, steel skidplate, Hilton Stage 1 tune, big burly tires
2008 S80 V8 245,000 KM SOLD!
2015 V60 T5 Premier+ 98,000KM
- pkc303
- Year and Model: 1995 T-5R Yellow
- Been thanked: 3 times
They are easy. If you can change plugs, you can do it. You have a bunch of help on this board.
1995 Volvo 850 T-5R Yellow
1997 Volvo 850R (sold)
2003 Volvo V70 2.4T, K&N air filter, (sold)
1996 Volvo 940 (sold)
1992 Volvo 740 Turbo (sold)
1990 Volvo 240 Wagon (sold)
1987 Volvo 240 Wagon (sold)
1982 Volvo DL (sold)
polskamafia mjl
- Has thanked: 19 times
- Been thanked: 21 times
ChiNorm wrote:Do get the heavy duty IPD links, which last about 10 times longer than the OEM, especially if you have the IPD sway bars.
Good luck.
+1
bigdaddylee82
- Year and Model: '95 850 GLT+94 parts
adventurer2112 wrote:Hi 95 850 na 165K,
Jack
I think everyone handled the sway bar link question well enough already. I bought the cheaper after-market links from FCP last week, and will have them as well as a lot more new suspension parts on this weekend. I haven't seen the HD links other than on IPD's website, but even the cheaper links from FCP are beefier than what's on my car right now.
I searched eBay, and if were talking about the same 850, it looks like a mad science experiment gone wrong. I believe the HHO nonsense to be "snake oil." However with some tuning via the Megasquirt computer, and diligent throttle control I believe that those mileage numbers they are claiming are probably doable.
Megasquirt is a DIY engine management system that can be used to control fuel and/or spark in place of or along with the factory computer in any car. Megasquirt uses GM sensors and is completely tuneable/adjustable via a computer and data cable with the Megatune software. Megasquirt is targeted at the budget minded DIY auto tuner. Check out diyautotune.com it's a pretty dang neat apparatus, you can literally buy the circuit board and all of the gizmos to solder together your very own engine management system if you want.
- Lee
adventurer2112
HI All,
Thank you very much for your great knowledge and patience with this newbie mechanic. I love my 850, although the 740 was way easier to simple stuff.
Thanks again.
Jack
Thanks again.
Jack
- 34 Replies
- 9357 Views
Last post by E Showell
- 857 Views
Last post by FCPEURO
- 1447 Views
- 2316 Views
Last post by theWIFES_S70
- 14 Replies
- 3400 Views
Last post by subzerocarfanatic
