O2 sensor replacement
vooman
Year and Model: s60, 2002
Post by vooman »
On a 2002 S60 2.4 what 's the procedure for replacing the rear O2 sensor? Please be gentle - I don't even know where it is.
Thanks!
JRL
Year and Model: Several
Been thanked: 16 times
Post by JRL »
Why do you think you need a rear 02 sensor?
The front is usually the one that goes bad
(and you need to have the car on a lift for the rear, can't see it or get to it from under the hood)
vooman
Post by vooman »
CEL was on - local shop said error code "442" which they say is the rear o2 sensor (another code was for a faulty gas cap). My cheap reader didn't return any code at all.
Is there any other way to check for go/no-go of the sensor(s)?
Thanks for the assist!
endothrow
Year and Model: S60 T5 2002
Post by endothrow »
vooman- with the price of a dual-band O2 sensor, I would hold off on replacing that since there are lots of factors that can make an O2 sensor throw a code, namely the emissions system.
I am not sure of all the specifics of what to check, but I would trace the issue back to the engine and start checking with the cheapest thing first in the combustion process. How is the car idling if that O2 sensor has a code? Rough, missing?
2002 Volvo S60 T5- K&N, Royal Purple fluids, OBX DP, Iridium Spark
jblackburn
Year and Model: 1998 S70 T5
Has thanked: 9 times
Been thanked: 19 times
Post by jblackburn »
P0442 is a code for the evaporative emissions system.
http://volvoforums.com/forum/showthread.php?t=5714
I would start by checking lines and elbows at the charcoal canister - look in front of your right rear wheel for the canister laying on its side.
'98 S70 T5
2016 Chevy Cruze Premier
vooman
Post by vooman »
It idles well, in fact it runs pretty smoothly at all times.
I'll check the canister and hose from the engine back.
Thanks all.
