Is this normal?
xallenx
Year and Model:
Is this normal?
Post by xallenx »
See video:
Sorry kinda dark, but you can see that I could easily jiggle it. Is this normal? It's nice and warm her in Charleston and I finally turned on the a/c. Noticed that every time the compressor kicks in I feel a vibration in the steering wheel. But when the compressor kicks off, the vibration is gone. Any suggestions? Thanks.
95 850 NA 279K on 1st motor (78K on the 2nd)
06 xc90 FW 2.5T 86K+
jimmy57
Been thanked: 320 times
Post by jimmy57 »
Yes, normal. If you replace it be will tighter for a short time. That is supposed to be a motion limiter and not really a mount. The earlier style that was pressed in was FAR more failure prone.
Steering shakes is somewhat normal with 5 cylinders. The idle speed is temp dependent and when weather warms up (I think ambient of 86F) the engine speed will go up 75 RPM or so and the vibes with compressor running will be less.
The RH engine mount under the front of engine is the one most likely to contribute to the vibes you are feeling.
xallenx
Year and Model:
Post by xallenx »
Thanks...i'll check it out!
The Blue Whale
Year and Model: 06 xc90, 2011 xc60,
Post by The Blue Whale »
My 06 xc90 (t5) vibrates like that at times when it is first started.
Now I know why.
