Oil Leak on 240 DL
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
james
Oil Leak on 240 DL
Post by james »
How do I fix a persistant oil leak on a 240 DL. Seems to be between the engine and transmission
Guest
Post by Guest »
Pull engine, remove flywheel, replace seal, replace flywheel, replace engine.
I assume that you have already cleaned your flame trap, if you have not, do that first and see if it fixes the problem.
