Oil Leak on 240 DL Topic is solved
james
Oil Leak on 240 DL
How do I fix a persistant oil leak on a 240 DL. Seems to be between the engine and transmission
Guest
Pull engine, remove flywheel, replace seal, replace flywheel, replace engine.
I assume that you have already cleaned your flame trap, if you have not, do that first and see if it fixes the problem.
