Power Steering Boot
shookone
Year and Model: 2001 V70 T5
Power Steering Boot
Post by shookone »
My power steering is leaking alot, i found the cause to be this plastic black boot on the rack leaking when i move the steering wheel. (driver side). It looks like a clamp fell off or something. I have looked a replacement parts but no of them say if it has a clamp on that end towards the center of the car. The boot just slides and back exposing some rod. Is there a clamp for that, or how does it connect back?
shookone
Post by shookone »
Its the rack and pinion bellow...is there supposed to be a clamp on that side?
otis44
Year and Model: 2006 S60 T5
Post by otis44 »
The boot should be clamped on both ends, but I believe the boot is more or less a dust protector and does not actually hold fluid. Sounds like you may have a seal that has failed.
JRL
Year and Model: Several
Been thanked: 16 times
Post by JRL »
That would be an inner tie rod.
The rack is leaking into the tie rod
No seals, no fix, replace the steering rack
shookone
Post by shookone »
Thanks....
shookone
Post by shookone »
One more question, while i was searching who sells a good rack. Dealership $900...misc web sites $200-$300 but dont know the quality.
writer100
Year and Model: 940 1994
Post by writer100 »
What you will typically get is a rebuilt rack which includes the inner tie rods. I don't have a name to recommend; just try to get the longest warranty available.
1994 Volvo 940: 189,000 miles.
2008 Mustang GT convertible: 10000 miles. The garage queen.
Reys
Year and Model: 850T estate '96
Post by Reys »
I have the same leak, I called the volvo dealership and the guy thinks its an o-ring that comes with the boot kit, is this o-ring replaceable? anyone try this?
IVIUSTANG
Year and Model: 2006 XC70
Been thanked: 4 times
Post by IVIUSTANG »
I had that same seal catastrophically fail on my 2006 XC70, it was a result of the torn boot around the inner tie rod; it allowed contamination to destroy the seal overtime till one day it puked out ALL the fluid in a very short amount of time. I found a low mileage replacement for $175 at a junkyard, and it is working perfectly.
Jesse
1998 S70 T5 SE 290,000 KM sideswiped total loss(Sweet ride!)
2007 S60 2.5T loaded 63,000 KM SOLD!
2006 XC70 350,000 KM, 2" BadSwede lift kit, steel skidplate, Hilton Stage 1 tune, big burly tires :D
2008 S80 V8 245,000 KM SOLD!
2015 V60 T5 Premier+ 98,000KM
Been thanked: 472 times
Post by cn90 »
For those who replaced the steering boot in the past, what is the easiest way to do this?
The 2006 S60 (or any Volvo in the Midwest exposed to salt) usually has seized tie rods where the INNER meets the OUTER...
Can you slide the boot from the inner side of the outer side if you don't separate the 2 parts?
