P0103
jbo6924
Year and Model: 1998 v70 t5
Re: P0103
Post by jbo6924 »
Well gentleman removed both battery cables, allowed 2 hours for drain. Reconnected and not only got immediate CEL, but also threw a single NEW code, although related to MAF not Sure of the Specifics. Here it is...P0102. THis is the only code out there that came up right away. Should the reconnection of the MAF be done in any special order? Like before or after the batteries are reconnected, or anything ritual in nature to do this correctly?
JIm :?
jblackburn
Year and Model: 1998 S70 T5
Has thanked: 9 times
Been thanked: 19 times
Post by jblackburn »
Also a MAF error code. Clean the connector with some rubbing alcohol and a Q-tip. Pinch the connector close or use a zip tie or something around the connector. If it still comes back again you just need to replace the sensor.
'98 S70 T5
2016 Chevy Cruze Premier
jbo6924
Post by jbo6924 »
I will try that today and let you know.
Thanks,
Jim
jbo6924
Post by jbo6924 »
Looks like I'm in for a new MAF!@#$%**&^%$!
Where's the best OEM Value...anyone?
Been thanked: 471 times
Post by cn90 »
Use BOSCH Only.
jblackburn
Check out the parts vendors - FCP Groton, Eeuroparts, and Tasca Parts. Tasca usually charges a boatload for shipping, though.
Yeah, don't use an aftermarket one you get from an auto parts store or something. They just don't work; or won't work for very long. I saw one guy that had gone through 4 from Autozone within a few months of each other.
'98 S70 T5
Pistol Pete H
Year and Model: 2002 V70 x/c
Post by Pistol Pete H »
I have a brand new Bosch maf sensor installed, and my keeps throwing a PO102 code everytime I drive it, and I can't spool up the turbos, , it will accelerate gradually, but if I need to cut in the turbo quickly, it bucks and wants to stall ?? Anyone have any ideas aside from clearing computer ?
jblackburn
Pistol Pete H wrote: 18 Sep 2017, 05:48 I have a brand new Bosch maf sensor installed, and my keeps throwing a PO102 code everytime I drive it, and I can't spool up the turbos, , it will accelerate gradually, but if I need to cut in the turbo quickly, it bucks and wants to stall ?? Anyone have any ideas aside from clearing computer ?
Blown or loose IC hose?
'98 S70 T5
jblackburn
jblackburn wrote: 18 Sep 2017, 08:47
Blown or loose IC hose? Wiring?
'98 S70 T5
Pistol Pete H
Brand new wiring harness, new maf, new map, basically new everything, please give me a reference to IC HOSE, and thanks,
