A little background info:
- 162,000 miles on my car, original engine, original transmission.
- New XeMODeX ETM 13,000 miles ago, no issues.
- Transmission shifts very well up and down the gears.
- ATF has been changed often, is very clean, and at perfect level.
Coincidence:
- 2 days ago I installed a new intake pipe ("sconeman"/snabb pipe, popular on VolvoSpeed).
- 1 day ago attached a clamp-on K&N cone filter
Problem:
I was driving on the highway today, and while at 65 MPH and about 2000 RPM, suddenly it seemed to drop out of overdrive as if I had pushed the pedal hard to downshift. The RPM shot to about 2500, then after a few seconds, they went back down. This happened several times.
I sped up to 75 MPH and the engine was racing but the tranny did not want to lockup until I let off the gas just a tiny bit. It then bounced back and forth out of lockup a bit like before. I was driving on some rolling hills, but the behavior was definitely abnormal.
FYI: There was NO flashing up arrow or check engine light while any of this was happening.
Reasons?
I talked to Justin and we thought of some possible scenarios...
1. Transmission is losing overdrive lockup capability and slipping.
2. New intake = little more power, especially on freeway. Maybe computer is confused?
3. Something else electronic making the car think it needs to downshift.
4. ???
Justin noted that it's unusual for a transmission to be slipping out of OD like that without the flashing arrow. He also suggested I try and go into cruise control and see if the same thing happens. I think I will pull the battery tomorrow to reset computer as well.
Help! I gotta home in a few days...
