Old Radio/CD/Tape Combo
axlaxl
Year and Model: S70 Base, 1998
Post by axlaxl »
98 S70 with the gigantic combo CD/Tape/Radio which I am assuming was factory installed. I am a bit tired of listening to FM and quite honestly I have not owned a CD (let alone a tape) for about 4 years. Using my iPod through the tape adapter is awful.
I want to get a new unit but since the one installed is twice the size of a normal radio I'm not sure what my options are once the factory behemoth is pulled out.
1 - Is there some sort of tray or something that goes in the other half of the slot?
2 - How hard is it to pull this monstrosity out and install a new radio and "tray".
3 - What is the tray called other than "tray" and where would I get one?
4 - Any suggestions on inexpensive speakers. It has 8 speakers from what I can tell. 2 x dash, 2 x front doors, 2 x read doors, 2 x rear seats.
5 - Any suggestions on a low end radio that will be easy to install (ie no need to splice and match wires)?
Thanks in advance for any and all advice.
ojdorson
Year and Model: 850R, 1996
Been thanked: 3 times
Post by ojdorson »
If you're sure you want to just get a single din radio, read this link - http://volvospeed.com/vs_forum/topic/74 ... n-850-new/
Otherwise, look at double-din units. http://www.crutchfield.com/g_300/Car-Re ... Double@DIN
I highly recommend something with built-in Bluetooth calling, a usb port for your iPod, and I really like the Kenwood Excelon units for quality features.
zhenya
Year and Model: 97 855 T5,98 V70 AWD
Post by zhenya »
Another option is to install a proper iPod adapter to the cd changer inputs. These work great - and while it may cost as much as a new radio, you retain the stock look (meaning it won't attract thieves) and simplicity (most aftermarket systems are ridiculously hard to use).
corradoandt5v70
Year and Model: T5 v70 2001
Post by corradoandt5v70 »
Try the SCOSCHE transmitter found in the automotive dept at wal-mart. It has no distortion like all the digital fm transmitters, It works great and is far cheaper than a new radio at only 15 dollars.
jblackburn
Year and Model: 1998 S70 T5
Has thanked: 9 times
Been thanked: 19 times
Post by jblackburn »
Whatever you do, PLEASE BUY A HARNESS and don't cut and splice things. It makes it a huge mess for owners to figure out afterwards.
The tape player/iPhone method works just fine for me :mrgreen:
I've always liked Alpines if you want to go aftermarket, though.
http://www.crutchfield.com/s_500CDA105/ ... and|Alpine
The cubby is called a "dash pocket"
'98 S70 T5
2016 Chevy Cruze Premier
