More horsepower
More horsepower
I have a 95 850 GLT NA. Back in the sixties I had quite an infamous relationship with local law officials because of my propensity for street racing. I used to run a 65 GTO with a 389 punched, crane, edelbrock, hooker, holley, accel, etc. It was a formidable machine. Now I am an old man and have developed an affinity for this Volvo
Question is how can I get some horsepower and torque out of this thing without hindering driveability too much and/or cause unnecessary damage to electronic monitoring
Git Er Done
dbeckwith
264,000 miles
dbeckwith
264,000 miles
jblackburn
- Year and Model: 1998 S70 T5
- Has thanked: 9 times
- Been thanked: 19 times
Not much you can do to an NA motor.
You can upgrade the intake system a small bit to draw in more cold air.
See this link for more info on what cheap things can be done to an NA:
https://www.matthewsvolvosite.com/forums ... 70#p132070
'98 S70 T5
2016 Chevy Cruze Premier
JDS60R
- Been thanked: 3 times
The N/A has limited resources for increased power. Many have asked the same question and without grinding your own cam you are looking at 5-10% increase at best (over the range -not just peak).
Best solution is to graduate to a high power turbo. It is cheaper and easier to buy a second car . A turbo motor,trans, computer, electronics and dash swap can be done If you are skilled in all of those areas. I use my N/A as a parts getter and loaner car to friends. It has a hitch and is great for gas mileage. Meanwhile my high pressure turbo awaits in the garage for my urge to move quickly.
Keep in mind sight and response times diminish with age. Make sure you have good lights and great brakes. Do not use crazy super bright lights as it attracts the local police. (One of the highest reasons impaired drivers are pulled over is for driving with high beams on - LEO's look for bright lights). I understand that the yellow wavelength (normal bulbs)are supposed to help with definition and clarity. I know very little in this area so maybe someone else will chime in and explain.
Retired
- 2439 Views
Last post by beigg
- 647 Views
Last post by charleskennedy23
