The right hand, rear position bulb on my 2002 V70 D5 SE needs replacing. This happened a while ago so I gave it a slap and it came back on for about a month, then went out again, slapped it again, worked, then went out for good.
So, this morning, over 2 hours ago, I thought I'd finally replace the bulb. Looked on-line and was really impressed at how easy it is to twist the huge handle things, pop out a bulb, pop a new one in and away you go. Not so. It's the top bulb of the lower cluster which, for some reason, has a different thing holding it in that won't budge, doesn't twist and requires all the skin off your hand before you get anywhere. I've got to the no skin on my hand stage and that's it
Many thanks
Joe
