To DIN or DOUBLE DIN...That is the question
shagginwaggin
Year and Model: 1994 850W 5sp
Re: To DIN or DOUBLE DIN...That is the question
Post by shagginwaggin »
I'm going to attempt to do the DD install and post back pictures / issues when done (probably in a new thread).
FCPEURO
Year and Model: 2006 XC90 V8
Been thanked: 19 times
Post by FCPEURO »
Double DIN or nothing. I think the Single DIN just looks cheap with the pocket underneath.
micah861
Year and Model: 98 S70, 98 S70 T5M
Post by micah861 »
FCPGroton wrote:I know when I replace my stereo in the 850, I am going to fit a Double DIN LCD GPS unit in there. Figured, if I was going to do it, I might as well do it right.
those things are awsome! :mrgreen:
Red 98 S70 T5M
Black 98 S70 N/A
schmidm90
Year and Model: 2000 V70 XC AWD
Post by schmidm90 »
I just installed a Pioneer Double DIN radio in my 2000 V70XC. The radio I used is the Pioneer AVH-3200BT. I also have the optional navigation unit.
https://www.amazon.com/Pioneer-AVH-P3200 ... B00385I7TU
I couldn't find a kit to install the radio so I made my own. The radio was previously installed in a 1995 Accord and I still had the fit kit from that on the radio. I cut all the tabs off the plastic fit kit and realized that it would fit snuggly except for the two rails that the original Volvo radio attaches too. I cut all the tabs of the fit kit. I then measured out the height of the two rails in the opening and using a dremel, I cut the same size slots into the plastic on the side of the radio. Once this was done, it took a little tweaking but it fit and is in nice and tight. there was enough room to hide the navigation until behind the radio and run the antenna
If you want more detailed pictures of the install PM me but I have attached one of the final install. Let me know what you think!
2000 V70XC - 199k
1981 VW Vanagon Diesel Westy - 220k
maverickbna
Year and Model: 1996 850
Post by maverickbna »
So are there any mounting kits necessary for double DIN radios? Or just Dremeling down the area surrounding the mounting. I have a '96 Volvo 850 with the SC-710 stock radio currently.
schmidm90
Post by schmidm90 »
I think it depends on the double DIN radio you plan on putting in. I would measure both just to be sure if you need a fit kit or not. The pioneer I installed fit just into the original slot and using the fit kit from my accord it fit perfectly except for the little spot in the bottom I need to fill.
2000 V70XC - 199k
Been thanked: 472 times
Post by cn90 »
I understand this is an old post but my question is about THEFT.
Many many years ago, thieves would break in the car to steal the hand-held GPS (Tom-Tom, Magellan etc.). Fast forward 15 years later, thieves no longer break in car to steal these hand-held GPS devices, simply because there is no "black" aftermarket for these things, thanks to the invention of the smart phones with GPS.
Having said that, I am considering getting rid of the factory radio (SC-816) and replace with Double-DIN with GPS features. Used units are about $200 on ebay and new is about $450+. I'd probably go with used but...my main concern is THEFT!!! I hate dealing with smashed window, police report, insurance company. Basically a waste of time and hassles etc.
So, the $1M question for you guys: do you think Double-DIN is a target for thieves?
clifford06
Year and Model: 2000 T5
Has thanked: 6 times
Been thanked: 4 times
Post by clifford06 »
Does any company make a detachable face double DIN ?
Matty Moo
Year and Model: 850, 1996
Been thanked: 30 times
Post by Matty Moo »
I just installed a single-din Alpine deck in my S70 last night with an Infinity Basslink.
The main reason I went with a single over a double is that all of the kids want double-din, so if something is going to get stolen that's what they are after.
http://www.midwest-abs.com
Simplycleanpowerwash.com
1999 s70 Plain Jane.
2000 s70 GLT
2014 Ram
2012 Jeep Wrangler Unlimited
mikealder
Year and Model: V70 2000
Been thanked: 13 times
Post by mikealder »
I put something like This In the V70 when the OEM unit packed up, it's been in the car over 4 years with no issue, to be honest when the screen is off it doesn't look like anything fancy from outside the car. Cheap and not a bad unit with lots of features - Mike
