V40 driveshaft types and changing
Help, Advice, Owners' Discussion and DIY Tutorials devoted to the second generation C70, S40 and V50 Volvos -- awkwardly model year 2004 ½ onwards -- plus where to go for advice and discussion on Volvo's sporty C30 Coupe powered by Volvo's ubiquitous inline 5-cylinder power plant.
V40 OWNER
Year and Model: V40 2001
Re: V40 driveshaft types and changing
Post by V40 OWNER »
The saga continues! Could not get the inner cv joint out from the gear box so I separated the rubber boot and pulled the tri-bearing out. So I now have the shaft out, knocked off the outer cv joint no probs, tried the new cv joint on it , too big for the shaft! AAAGGGHHHH!!!!
Having spoke to the cv joint suppliers, 99% of the joints are this one, but the other one ( which they dont stock ) they will have to fly from Holland.
I also have a complete shaft from a T4, BUT this is not the same either.............
Have you ever thought you are cursed at some point!
GRRRRR
V40 OWNER
Post by V40 OWNER »
The continuing saga!
OK just received a second CV Joint , internal splines spot on, everything looking good, BUT the ABS ring is not in the correct place......AGGGGGHHHHH!!!
billofdurham
Year and Model: 855, 1995
Been thanked: 5 times
Post by billofdurham »
Oh, the joys of motoring!
I thought the ABS sensor sat in the spindle.
V40 Front ABS sensor.pdf
(49.71 KiB) Downloaded 318 times
Bill.
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
