SC901, C70 4x100w Amp, iPod & Aux in and all wiring needed*
ojdorson
- Year and Model: 850R, 1996
- Been thanked: 3 times
Re: SC901, C70 4x100w Amp, iPod & Aux in and all wiring need
My hastily made video. It is by no means a comprehensive guide, just a quick overview.
c70_lindsay
- Year and Model: 99 S70 T5.
Hi Cool write up. Could you give more info on how to wire the 6cd input to an aux in, pictures would be great. I spent $300 to get a mp3 input wired to work through the radio antenna and it sounds like trash. Thanks
ojdorson
I have a direct Aux in. There are a few models available. As this is a "For Sale" thread, I'll sell you mine for $40 shipped with all the related wiring and the user's manual. You need to wire it in to 12V (constant), !2V switched (ignition) and ground.c70_lindsay wrote:Could you give more info on how to wire the 6cd input to an aux in, pictures would be great.
burnout8488
- Year and Model: 1999 S70 AWD
You have PM
'13 BMW X1 35i M-Sport
'99 S70 AWD/FWD - 198K - FOR SALE!
ojdorson
Everything except the amp and the DIN cable is sold. Since I pulled it out, I'm going to detail what it takes to wire up your own pass-through SC-901 retrofit harness in a write-up shortly.
lttrcrrr95
- Year and Model: 1997 850 non-turbo
Question : Do you wiring the power from the amp straight to the battery? Ground to seat bolt, two power lines to battery with 40 amp fuses inline? I have an 850 was going to set up amp and install sc900 right to my 850. But the sc900 has to use amp. I have the din cable to go from amp to sc900. Was just going to plug in sc900 to my 850 connector. But not sure if powering the amp.
Bill
Bill
