question about motor mounts
mkelly3585
- Year and Model:
bronxnativ
- Year and Model: 96 850 GLT 5 Speed
Well, as you already know, the top is shot. As far as the lower (looks like the lower one on passenger side) looks good to me, although I had to bend my head like a pretzel to take a good look at it.
As far as Poly's: I'm OK with it. It does cause extra vibration but it is something I can live with. Most here will shy you away from them so be prepared for the feedback!
Al
mkelly3585
- Year and Model:
I want to get it fixed the easiest cheapest way possible. My son is taking it to college in a month and I just want to make sure it's safe, not really concerned with vibration
kiss4afrog
- Year and Model: 850 1995
- Been thanked: 2 times
I went with the IPD poly one. It was a snap using a chisel to knock out the old one and it installed easily. Haven't noticed any extra vibration.
You can never have too big a Turbo !
If you want real cheap go to lowes or home depot and get polyurethane in a calking gun and remove the motor mounts tape up 1 side and fill it with poly. I do that to all mine there nice and stiff but not too stiff and I've had mine on for over 3 years and they're still holding up great just google it that's where I found it and it works trust me
- Has thanked: 312 times
- Been thanked: 818 times
IIRC the poly torque mount bushing is like $40 at IPD but $30 most places, e.g. FCPGroton or eEuroparts.com. Poly will definitely be the easiest solution.
If you are set on cheapest you can buy an aftermarket rubber bushing from one of the online suppliers for less than 10 bucks. It is more work to put in and will break in about 10,000 miles but you said cheapest ...
- 1491 Views
- 688 Views
Last post by GlennG2759
- 9 Replies
- 2042 Views
Last post by charleskennedy23
- 1354 Views
Last post by sleddriver
- 1049 Views
Last post by IslandV70
