I have a '94 850 Wagon and have been trying to restore the flow of cleaner to my front wipers. I have checked all the valves (soaked them in vinegar to remove deposits, cleaned them up, and after verifying that they were in working order, reinstalled). I have also checked all the lines that I can find. I can hear the pump running. I would like to remove the pump, inspect it, and see it operate outside the reservoir. Do I have to drop the reservoir to do this?
The valve under the hood that is supposed to keep the fluid from draining backwards... It seems to be working, but if not, would it prevent flow to the hood or only make the response time longer (wear on the pump)?
Any suggestions would be appreciated!
