Driver-side Rear Window Regulator Replacement
I need to replace my driver-side rear window regulator. Can anyone offer some advice or VADIS pictures? I see plenty on front window info on sites, but cannot find for the rear. Already have the panel off and rivets drilled out (not sure if all of them though).
dcarlson12
- Year and Model: 1997 850 T5
- Been thanked: 2 times
Couple files from VADIS. Hope this helps.
Window lift mechanism rear side door replacing S80 2000.pdf- (86.06 KiB) Downloaded 2344 times
Drip guard replacement S80 2000.pdf- (110.68 KiB) Downloaded 940 times
Thank you! This is perfect. I never would have thought of the rivets on the window retainer, and was scratching my head on that. These guys certainly couldn't make things easy with screws, bolts and nuts.
Do you know how critical it is to use "volvo" rivets over something I can get locally?
A thank you to dcarlson12 for posting the files from VADIS, it helped me replace my left rear regulator. Drill out four rivets, and unbolted one nut to remove broken one. To replace, I bought the rivets from volvo but couldn't put them in with my 12" rivet gun. Went back to dealer with new regulator just bolted on with the one nut and asked them to rivet in. They used an air rivet gun to do it, so easy with the right tools.
ADent
- Year and Model: 2001 V70 T5M
- Been thanked: 5 times
I used a 1/4" drill on the rivets to take them out.
I bought 30640780 rivets - The main rivet body is .185" in diameter and .400" in long. Weakly magnetic, so I guess stainless.
2001 V70 T5M
1988 740 GLE 5.0
1988 740 GLE 5.0
- 3839 Views
Last post by joejoethedogfaceboy
- 12 Replies
- 3090 Views
Last post by BEJinFbk
- 2537 Views
Last post by zwieback
- 467 Views
Last post by aahmes57
- 2676 Views
Last post by mnmk
