Hideous vibration after renewing engine mounts
Marcobrick
- Year and Model: 2003 V70T5
- Has thanked: 3 times
I am gutted. I spent many hours doing work on my car the last few days including timing belt, PCV, hoses etc. I also replaced right hand engine mount (under the crank) and the rear hydraulic mount. The old mount looked fine, but I couldn't get the bolt through the upper torque bush when I replaced it. It was as if the engine were leaning too far back. So I replaced that rear mount and it's better, but I still have to pull the engine forward about a quarter inch to slip the bolt through. The vibes are very pronounced below 2000rpm and I can feel them quite strongly in the steering wheel which makes me partly suspect the new rear mount as it is perched on the steering rack. I have the torque bush in the right way around so I can't figure out why I can't just slip the bolt through. The only mount that is still original is the front hydraulic one, ALL the others have been replaced within the last 200 miles. Help! It's hideous to drive now, in fact it was smoother with all the broken mounts!
2008 XC90 D5
2014 Nissan Leaf
1973 Fiat 125
1970 MGB GT
1973 Land Rover Series 3 flat deck.
Previously:
2003 V70T5
1996 850R sedan
1994 850T5 Sedan
1995 850 Turbo Wagon
1998 V70T5
Favourite line: "How hard can it be?"
2008 XC90 D5
2014 Nissan Leaf
1973 Fiat 125
1970 MGB GT
Previously:
2003 V70T5
1996 850R sedan
1994 850T5 Sedan
1998 V70T5
JRL
- Year and Model: Several
- Been thanked: 16 times
Replaced with what?
Stock OEM mounts. If you used POLY bushings these cars will vibrate
JRL wrote:Replaced with what?
if they are too stiff they wont absorb and of the vibrations made by the engine. also if u have 1 old one left then everything could be forced ever so slightly out of position which i would think could easily lead to vibration.
1998 S70 T5 SE 214,001
1999 v70R 126,000
1999 v70R 126,000
Marcobrick
new mounts are all rubber. Not a poly in sight after reading posts on the subject.
2008 XC90 D5
2014 Nissan Leaf
1973 Fiat 125
1970 MGB GT
Previously:
2003 V70T5
1996 850R sedan
1994 850T5 Sedan
1998 V70T5
2008 XC90 D5
2014 Nissan Leaf
1973 Fiat 125
1970 MGB GT
Previously:
2003 V70T5
1996 850R sedan
1994 850T5 Sedan
1998 V70T5
SimLyons
- Year and Model: 2001 V70 T5
A word in defense of the Poly mounts: #3-4 years ago my top mount (egine to firewall) shredded (as is common) and I decided to try the poly from IPD. I've added about 40K miles in that time and have NO vibration issues. Never had with the poly. I had one installed on the lower trans mount too. Same deal. Maybe engine mounts are different, but these guys (top and bottom) are getting a bad rap.
Sim
bronxnativ
- Year and Model: 96 850 GLT 5 Speed
I agree and disagree. I've used them over a year, and it seems in hotter weather, the vibration tends to be less BUT wait til winter comes around! In the cold, they absolutely do vibrate after initial start-up. Overall, I am happy with their performance (Polys)SimLyons wrote:A word in defense of the Poly mounts: #3-4 years ago my top mount (egine to firewall) shredded (as is common) and I decided to try the poly from IPD. I've added about 40K miles in that time and have NO vibration issues. Never had with the poly. I had one installed on the lower trans mount too. Same deal. Maybe engine mounts are different, but these guys (top and bottom) are getting a bad rap.
Al
Marcobrick
As an update, the vibration abates somewhat when the engine is heat soaked for example after a 30 minute drive. I think I will replace the front hydraulic mount and then at least I know all the mounts are brand new.
2008 XC90 D5
2014 Nissan Leaf
1973 Fiat 125
1970 MGB GT
Previously:
2003 V70T5
1996 850R sedan
1994 850T5 Sedan
1998 V70T5
2008 XC90 D5
2014 Nissan Leaf
1973 Fiat 125
1970 MGB GT
Previously:
2003 V70T5
1996 850R sedan
1994 850T5 Sedan
1998 V70T5
Marcobrick
Replaced the front hyd. mount yesterday. Quite easy I found with the fan removed. The new one was a good half inch taller than the old one.
I have now replaced EVERY engine mount and bush with brand new. No poly bushes were fitted. It still buzzes! It's tolerable when the engine has been at operating temp for more than 20 minutes but still nothing like as smooth as my sedan with the same mileage and original mounts except for top engine torque bush.
Is there a break in period with new bushes? (sounds silly even as I type it)
2008 XC90 D5
2014 Nissan Leaf
1973 Fiat 125
1970 MGB GT
Previously:
2003 V70T5
1996 850R sedan
1994 850T5 Sedan
1998 V70T5
2008 XC90 D5
2014 Nissan Leaf
1973 Fiat 125
1970 MGB GT
Previously:
2003 V70T5
1996 850R sedan
1994 850T5 Sedan
1998 V70T5
D_V_ENT850R
- Year and Model: 850R 1996
I replaced my upper rear torque mount(at the firewall) and it has a vibration it didn't have! But it's better than the loud thump sound every time I accelerated!
Marcobrick
What brand was that mount?D_V_ENT850R wrote:I replaced my upper rear torque mount(at the firewall) and it has a vibration it didn't have! But it's better than the loud thump sound every time I accelerated!
2008 XC90 D5
2014 Nissan Leaf
1973 Fiat 125
1970 MGB GT
Previously:
2003 V70T5
1996 850R sedan
1994 850T5 Sedan
1998 V70T5
2008 XC90 D5
2014 Nissan Leaf
1973 Fiat 125
1970 MGB GT
Previously:
2003 V70T5
1996 850R sedan
1994 850T5 Sedan
1998 V70T5
- 1617 Views
Last post by Legofan
- 2775 Views
Last post by jmscdgn
- 10 Replies
- 6179 Views
Last post by bichinavolvo
- 1445 Views
- 19 Replies
- 2642 Views
Last post by jonesg
