1998 V70 code PO 172
Harpoon
Year and Model: 1998 V70
Post by Harpoon »
JBlackburn; are you out there? I have code (PO 172/ system too rich B1) that I have reset about 5 times. I have cleaned the MAF, changed plugs, changed plug wires, coil, changed air cleaner, replaced temp sensor. Could this mean I need a new cap and rotor? I am also aware of a leak in my heater core. Could losing a small amount of coolant (not noticeable on temp gauge) be causing the computer to enrich the fuel so as not to overheat the vehicle?
I would greatly appreciate any advice/suggestions. Thank you in advance to all who offer up ideas/help.
vjaneczko
Year and Model: 2006 S60R
Been thanked: 6 times
Post by vjaneczko »
Sounds like a vacuum leak:
https://www.matthewsvolvosite.com/forums ... php?t=6283
Probably a good idea to look into replacing all of the hoses & elbows 'cause it sounds like you're in the middle of a Stage 0 - might as well continue the effort!
https://www.matthewsvolvosite.com/2009/0 ... s-stage-0/
1997 855 GLT - R.I.P.
2006 S60R - For ME!
jblackburn
Year and Model: 1998 S70 T5
Has thanked: 9 times
Been thanked: 19 times
Post by jblackburn »
95% chance it's the vaccum elbow at the left side of the intake manifold.
I fixed it with a small piece of flexible tubing to connect the two lines.
'98 S70 T5
2016 Chevy Cruze Premier
Harpoon
Post by Harpoon »
JBlackburn; am I able to get at this without removing the intake?
jblackburn
Yeah. Long needle nose pliers should help you with it.
It helps to have a girl's hands to help you (I have stupid big clumsy hands), or you can remove the radiator hose - which then makes everything a bit slippery.
Make sure you put a clamp on the hose or it'll just blow off again as soon as you put your foot in the gas pedal.
'98 S70 T5
Harpoon
Post by Harpoon »
Thanks!
