JBlackburn; are you out there? I have code (PO 172/ system too rich B1) that I have reset about 5 times. I have cleaned the MAF, changed plugs, changed plug wires, coil, changed air cleaner, replaced temp sensor. Could this mean I need a new cap and rotor? I am also aware of a leak in my heater core. Could losing a small amount of coolant (not noticeable on temp gauge) be causing the computer to enrich the fuel so as not to overheat the vehicle?
I would greatly appreciate any advice/suggestions. Thank you in advance to all who offer up ideas/help.
1998 V70 code PO 172
vjaneczko
- Year and Model: 2006 S60R
- Been thanked: 7 times
Sounds like a vacuum leak:
https://www.matthewsvolvosite.com/forums ... php?t=6283
Probably a good idea to look into replacing all of the hoses & elbows 'cause it sounds like you're in the middle of a Stage 0 - might as well continue the effort!
https://www.matthewsvolvosite.com/2009/0 ... s-stage-0/
1997 855 GLT - R.I.P.
2006 S60R - For ME!
2006 S60R - For ME!
jblackburn
- Year and Model: 1998 S70 T5
- Has thanked: 9 times
- Been thanked: 20 times
95% chance it's the vaccum elbow at the left side of the intake manifold.
I fixed it with a small piece of flexible tubing to connect the two lines.
'98 S70 T5
2016 Chevy Cruze Premier
jblackburn
Yeah. Long needle nose pliers should help you with it.
It helps to have a girl's hands to help you (I have stupid big clumsy hands), or you can remove the radiator hose - which then makes everything a bit slippery.
Make sure you put a clamp on the hose or it'll just blow off again as soon as you put your foot in the gas pedal.
'98 S70 T5
