S70 ('98) GLT Cam Lifters Out of Order
dorage
Year and Model: 2002 V70 XC AWD
Post by dorage »
I'm working on replacing the head gasket (1st time). I did not keep the cam lifters in order. Please advise. Thanks.
Year and Model: Many Volvos
Been thanked: 75 times
Post by Ozark Lee »
Welcome to MVS,
Keeping them in order is always the best method but many have swapped old lifters into a re-furbished head. Be sure to soak them in oil for at least 24 hours before putting them back in. If you can match any wear patterns so much the better.
FCPEURO
Year and Model: 2006 XC90 V8
Been thanked: 19 times
Post by FCPEURO »
+1
It stinks that they are not in order, but it is not the end of the world. Just soak them like Lee mentioned and you will ok.
jimmy57
Been thanked: 320 times
Post by jimmy57 »
Do not worry one bit. On these engines the pressure on lobes is very low. 4 valve motors have much lower spring pressure due to smaller valves and the lobe width and large tappet surface produce virtually zero wear. The only tappet wear I have ever seen was on an engine that had water in the oil and was run for a while that way so the tappets had rust pitting on the faces.
If your engine is tidy on the inside then you probably won't have any pattern wear on the tappets and they'll do fine. The precautions apply to 2 valve motors, especially V8's where the lobe width is small, spring pressure much higher, and the tappet face is 1/3 of what your tappets have.
dorage
Post by dorage »
Thanks guys!
