1986 245 Turn Indicators Not Working
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
mdm+mfm
Year and Model: 245, 1992
Post by mdm+mfm »
Some time ago, the turn indicators on my other Volvo wagon stopped working; however, the emergency flashers do work fine. Is there a separate flasher unit for the turn indicators? Is it possible the switch is bad? Should I be looking at something else?
billofdurham
Year and Model: 855, 1995
Been thanked: 5 times
Post by billofdurham »
Turn indicators and hazard lights work off the same flasher relay which, on the '86 240, is on the front left side of the centre console.
240 1986 relays..pdf
(120.98 KiB) Downloaded 191 times
It is not unusual for the indicators to stop and the hazard lights carry on working or vice versa.
Bill.
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
mdm+mfm
Post by mdm+mfm »
Hi Bill,
I did replace the flasher relay, but the problem still exists. Anything else that I should/could be checking?
lindy8_man
Year and Model: 1998 S90
Post by lindy8_man »
Check your signal bulbs. Check out the contacts, and any broken clips.
You can pull the switch from the steering column, and test it with a volt meter. You will need the wiring diagram to notice when the switch is working properly.
Shorts are fun!
Beer and DIY Volvo Repairs are proof that God loves us and wants us to be happy.
mdm+mfm
Post by mdm+mfm »
Although this is months late, thank you lindy8_man for the idea; I appreciate it. I have not been on the site lately due to my schedule and have not been driving the car either, but I will investigate further what might be causing the issue. Have a great weekend!
