Problems with boost Topic is solved
This topic is in the MVS Volvo Repair Database » Restoring performance to a Modded 850 T5 R
gmtgmt
Year and Model: Volvo 850 T5R
Volvo Repair Database Problems with boost
Post by gmtgmt »
Im working on a molested T5 R that has a problem with boost.
The guy who own it said it just at one point just lost all power.
Its mostly stuck 3" Downpipe, highflow cat, 2.5" Cat back, k&n filter in stock box and a boost controller.
All vaccum hoses at the turbo has been changed.
When we retrofited the original boost controler at the airfilterbox and add a boost gauge and removed the aftermarket boost controler we got about boost pretty consistant about 7 psi. Drove pretty good but still kinda sluggish
we checked the plug wires they where really bad
Cleaned up grammar, spelling and URLs. Embedded YouTube videos.
bad wire.jpg (65.62 KiB) Viewed 2492 times
plugs where good and orignal volvo
Changed the wires, cab and rotor to good but used volvo from a spare engine allready my better starting and drove much better.
We then took the aftermarket boost controller apart and the little ball that are used as a one way valve was stuck cleaned everything up nice and connected it to the turbo and disconnected the orignal and we got boost again at about 9psi still kinda sluggish and the owner says it dosent have the pretty loud "Blow off" anymore and he says it was alot faster also
So we thinking something else is wrong we where thinking the original blow off is stuck or the waste gate is done.
Here are 2 videos running with stuck boost controller and the aftermarket boost controller:
Any ideas?
Thanks, Thomas.
Juan62
Year and Model: S70 T-5M 1998
Post by Juan62 »
Compressor By-Pass Valve (CBV) diaphram...change the rubber and spring
98 S70 T5-M Brick for life
gmtgmt
Post by gmtgmt »
This one?
we where thinking about it but can it really do this?
Juan62
Post by Juan62 »
Yes, i did mine...small space but you can do it. That is the one....under the car to get to it.
gmtgmt
Post by gmtgmt »
Thanks will order a new one tommrow.
is this a commen failure?
D_V_ENT850R
Year and Model: 850R 1996
Post by D_V_ENT850R »
When I bought my car I was only getting 6psi changed the CBV and 10psi! Now at 14psi and boy is that fun!
gmtgmt
Post by gmtgmt »
Got the CBV removed and ture enough it had a hole :mrgreen:
Thanks
