Im working on a molested T5 R that has a problem with boost.
The guy who own it said it just at one point just lost all power.
Its mostly stuck 3" Downpipe, highflow cat, 2.5" Cat back, k&n filter in stock box and a boost controller.
All vaccum hoses at the turbo has been changed.
When we retrofited the original boost controler at the airfilterbox and add a boost gauge and removed the aftermarket boost controler we got about boost pretty consistant about 7 psi. Drove pretty good but still kinda sluggish
we checked the plug wires they where really bad
plugs where good and orignal volvo
Changed the wires, cab and rotor to good but used volvo from a spare engine allready my better starting and drove much better.
We then took the aftermarket boost controller apart and the little ball that are used as a one way valve was stuck cleaned everything up nice and connected it to the turbo and disconnected the orignal and we got boost again at about 9psi still kinda sluggish and the owner says it dosent have the pretty loud "Blow off" anymore and he says it was alot faster also
So we thinking something else is wrong we where thinking the original blow off is stuck or the waste gate is done.
Here are 2 videos running with stuck boost controller and the aftermarket boost controller:
Any ideas?
Thanks, Thomas.
Problems with boost Topic is solved
Restoring performance to a Modded 850 T5 R
D_V_ENT850R
- Year and Model: 850R 1996
When I bought my car I was only getting 6psi changed the CBV and 10psi! Now at 14psi and boy is that fun!
- 21 Replies
- 4405 Views
Last post by j-dawg
- 1452 Views
Last post by captainkong
