Hi-Flow Turbo Intake Tube and CCI System
How to go faster, stop quicker, and turn harder. Chips, exhaust, larger turbos, bigger/slotted/drilled rotors, high performance brake pads, manual boost controllers, performance shocks/struts/springs, airbox mods and more! Also discussion on HID and Xenon lights, aftermarket foglights and other exterior lighting.
Juan62
Year and Model: S70 T-5M 1998
Post by Juan62 »
98 S70 T-5M;
I was wondering if any has done this before or if this mod will work.
FCP Euro; Part # PFA-98X70, by (Snabb): Volvo High Flow Air Intake kit (replaces the factory Turbo tube).
Viva Performance; Part #VP-CB053, by (Simota): Carbon Fiber Intake System (replaces the factory air box/filter)...will need a SAS filter.
1. Will the two systems work together?
2. Will I need to get a Flex Tube to modify the factory air distribution tube (from radiator shroad to air box)?
Thanks
98 S70 T5-M Brick for life
Juan62
Post by Juan62 »
Update;
Go to http://www.snabb.us
These products are custom hand-made for Volvo's. If your Volvo is not listed on their website, call and ask for a custom pipe.
Intake 2.png (9.45 KiB) Viewed 7011 times
Intake 3.png (8.78 KiB) Viewed 7011 times
Intake 4.jpg (2.75 KiB) Viewed 7011 times
Juan62
Post by Juan62 »
Update: Will they work together,
Yes!!!
After purchasing and installation, I'll post a write-up and pics, but instructions do come with both (Simota and Snabb) kits. if you require a SAS filter, IPD (19.00) or Pep Boys, Autozone, and Advance Auto parts sells them too (multiple colors).
Juan62
Post by Juan62 »
Here is the CCI (Carbon Cold Air Intake) which replaces your factory air box/filter. For SAS filters, $10
http://www.vivaperformance.com
shiloh51933
Has thanked: 28 times
Been thanked: 17 times
Post by shiloh51933 »
Juan62 wrote:Here is the CCI (Carbon Cold Air Intake) which replaces your factory air box/filter. For SAS filters, $10
You notice any difference?
If U Wanna Play U Gotta Pay!!
Present Volvo Ownership:
2008 Volvo XC90 V8 Black
Previously Owned Volvo:
1996 Volvo 850 GLT Silver
1998 Volvo V70XC Dark Blue
2000 Volvo V70XC/SE Dark Blue
2004 Volvo XC90 T6 Gold
Juan62
Post by Juan62 »
have not purchased the items yet, but i know for sure replacing the air box with CCI system will be better than factory.
firebrick
Year and Model: 1994 Volvo 855 Turbo
Post by firebrick »
I cannot to wait for your report. Especially I am interested in how well Simota CAI will work. Do you know if Simota CAI is better than ipd version? How different are they? In theory, it shares the same idea, correct?
Juan62
Post by Juan62 »
Firebrick;
Yes, in theory, the concept is to keep hot air from the engine bay out...cold air=better response.
Now, the IPD's Short Air Ram is great, but it will capture some hot air from the engine bay. Why, because the air filter system is not fully sealed (like the factory air box). The Simota CCI system enclosed its air filter with a Carbon Fiber housing, thus, simular to the factory air box, but without the air box.
Both are capable and has its own unique benefits. Example; if Simota created a sheild like IPD, it would have both of the two worlds. If IPD created an enclosure (sealed) for its air filter....wow!
So I'm still researching if a company combines the two. So far, nada. And therefore, I will eventually incorporate both Simota, and IPD's version. Why, because IPD has the sheild and the HD TCV, and Coil pack locations are a great benefit=plug and play. Simota has the filter enclosure (sealed), together, I would reduce more engine bay heat from the system. The Volvo High Air Intake, is a great look and add-on with brass fittings. You are able to upgrade the hoses to braided Hi-performance connectors...looks professional (NHRA) stuff.
trophytaker308
Year and Model: 1995 850t turbo
Post by trophytaker308 »
i wonder if that one would be better than the one with the big cone filter and heat shield of course?
1995 850t turbo,siver with black leahter interior (perfect),, 118000 miles .second owner.9 out of a 10...!
Juan62
Post by Juan62 »
Trophytaker308;
The CCI (Black), yes thats much better.
This week i received the IPD's SR5T w/SAS. Now, I will order the Hi-Performance (Turbo) Fresh Air Intake form Snabb. And finally, the CCI systems. Why the SR5T and CCI? Because of the heat sheild, new input location for the coil, and HD TCV. I guess I could have cut the factory air box and fabricated something, but I chose the metal heat sheild...which to me,will compliment the entire system.
