I want to replace the right cv shaft on my 2002 S 80 T6. It seems there are two types. One with a voscous coupling, one without.
Is there any way of telling if I have a viscous clutch in my car?
Thanks.
2002 S 80 CV shaft.
1998 vs 1999 Changes & Differences
JDS60R
- Been thanked: 3 times
There is no viscous coupling in any of the CV shafts. They want to know if your car has All Wheel Drive.
Just call Marty at www.raxles.com and he will help you get everything right.
Retired
boosted5cyl
- Year and Model: '98 V70 T5, '99 S80
To clarify for others, some FWD S80s do indeed have a visco clutch. My 99 T6 has one for instance.
kawasakiklx
- Year and Model: S80 T6 2000
How can you tell if your car has a viscous clutch? I am trying to replace my shaft on the passenger side and I'm not sure what to look for.
There is a big, heavy looking thing between the transmission and the bearing mount that bolt to engine. Is that the visco clutch?
jimmy57
- Been thanked: 320 times
The VC will be a 4 inch by 3 inch (approximate size) housing on the axle shaft between the trans and the support bearing.
If your axle is roughly 1 inch diameter from trans to where that support bearing fits then you do not have the VC type shaft. I think the VC type were only 99 and part of 2000.
I had a 99 T6 with one.
kawasakiklx
Ok, there is a unit in that space but I'm not sure if it fits those dimensions. I will snap a pic tomorrow and post it here.
W/O the visco-cluth does the axle go straight from the bearing housing the the tranny or is there a round piece there either way? It looks like a thick saucer.
Thanks!
Thanks!
boosted5cyl
You can't miss the thing if you have it, its huge. It looks like a big lump of round metal on the driveshaft.
This is what it looks like...Big a$$ cylindrical drum, much bigger than the driveshaft...
kawasakiklx
hmm I think mine is not as wide but bigger around. Thanks for the pic!
- 3340 Views
Last post by bluesguys80
- 4626 Views
Last post by SuperHerman
