S70 moonroof doesn't close tight
CarVolvo
Year and Model:
Post by CarVolvo »
Lynn wrote:Thanks MIJ. Will do. Have a good one...
I just thought i would add my two cents to the thread.
My sunroof was not closing properly and i thought it could be the weather stripping around the edge.
I discovered it was a broken lever which moves the sunroof up on angle position and closes it. Now this is not easily seen unless you tak off the sunroof and the support bar underneath.
I copied this from bay 13 and circled it. If you see it from the other side it actually is not one piece but two. The one in the picture is the metal part..the other side is a plastic part. I found that first my roof would not slide back and this was because there was a piece of the shatterer part jamming the track where the sunroof slides back.
I then found later that the roof was not closing in proper position and this also had to do with the broken part.
After i lubricated and removed the blockage on the track i found that the power sunroof did work.... and slid back..but i would have to try it over and over again. But i know if i keep this up i will eventually snap something else on that side. So i am working to get this off a new donor car.
Hope this helps ! (hmm how do i attach a pic?)
THE FLEET!:
93 854 GLT 20v non-turbo 435,000 KM +
94 854 20v non-turbo 215,000 KM ..new engine
87 745 B230 non-turbo 250,000 KM (newest edition Jan '07)
86 244 GL B230 non-turbo 460,000+ KM
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2656 times
Been thanked: 1248 times
Post by matthew1 »
CarVolvo wrote: (hmm how do i attach a pic?)
https://www.matthewsvolvosite.com/chat/p ... hp?p=16880
Also -> Amazon link
CarVolvo
Year and Model:
Post by CarVolvo »
THE FLEET!:
Mike850
Year and Model: 1994 850, 1997 850
Post by Mike850 »
MIJ,
I need to replace the weather stripping on my sunroof and cannot locate it in FcpGroton's catalog. Can you direct me to where it is? Thanks a bunch!
1994 Volvo 850 GLT
1997 Volvo 850 GLT
MadeInJapan
Has thanked: 17 times
Been thanked: 35 times
Post by MadeInJapan »
I'll probably have to get you a part number and you'll have to call them with it. I'm looking for it but haven't found it yet. When I do, I'll post back.
Edit: Okay, I found the part number: #1390349
Good luck!
volvoaddict007
Year and Model: 760 Turbo
Post by volvoaddict007 »
Mike850 wrote:Thanks a bunch!
Off Topic here but I'll have to say I'm envious of Mike's 850 there. Isn't that a Turbo 'R' ? Your footnote doesn't mention it. Still cool to look at if not. The red 850s are great looking in person as well !
I really want one of those front spoilers for Christmas...any board members have suggestions since I don't have a chimney for Santa to get down? The plan for my white 850 is the pale yellow paint after I find the spoiler. The red is definitely a consideration though.
Back to the topic : Man, that picture by Matt of rust around the moonroof is scary! One of those times that my California emissions don't seem all that bad...:?
va007
1990 5 speed 760 Turbo Wagon 310K.
( '91 940 turbo eng. + trans.)
Konis, diesel springs, 2.5" exhst., 850 T5 wheels
1993 300ZX 2+2, 171K
1999 Ford Windstar LX, 90K
SpeedyPete
Year and Model: S70-T5, 1998
Post by SpeedyPete »
Hi Guys: I don't believe the 2 half moon shaped plastic parts are for holding the roof on under high speed conditions. MIJ reinstall them in your car with adhesive if necessary. They are for depressing the wind deflector so the rubber weatherstrip doesn't drag on the wind deflector with every operation of the roof. Best Regards, SpeedyPete :)
SpeedyPete
KlubMarcus
Year and Model: V70 XC, 1998
Post by KlubMarcus »
MadeInJapan wrote: Here is Bay13's write up on where the screws are, etc.: http://www.volvospeed.com/Repair/sunroof.php
Looks like a new URL volvospeed.com/volvo_repairs_how_tos/volvo_trim_parts/sunroof_adjustment_removal.html
:o The beater just won't die! So we're clawing our way back to Stage 0.
KlubMarcus
Here are some supplemental pictures of a 1998 V70 XC sunroof removal. Bay13 at VolvoSpeed already has good write-up.
Pull on the middle of the bottom plastic that shields the sunroof raising mechanism to pull it out of the track and then pop it up onto the top.
CIMG1779 (800x448).jpg (144.07 KiB) Viewed 1718 times
You can see a metal standoff to the right where the plastic shields snap on/off the sunroof raising mechanism.
CIMG1780 (800x448).jpg (193.64 KiB) Viewed 1718 times
Here is the plastic shield from the sunroof raising mecahnism scissored open. Good time to vacuum it.
CIMG1781 (800x448).jpg (125.72 KiB) Viewed 1718 times
Here is the plastic shield from the sunroof raising mechanism snapped together. You can see the snaps for the standoffs.
CIMG1783 (800x448).jpg (182.09 KiB) Viewed 1718 times
Re-assembled after wiping everything down and using silicone spray sparingly to lubricate moving parts. Too much will attract dirt.
CIMG1785 (800x448).jpg (215.55 KiB) Viewed 1718 times
