High beams not working on 1999 Volvo S80
cabooster
Year and Model: 1999 Volvo S80
Post by cabooster »
Hello all,
I am new to these forums and wanted to ask a quick question. First of all, I would like to say that I am driving a 1999 Volvo S80 with 80270 miles on it. Last week, I had a problem with my Voltage regulator which left me stranded in the middle of know where. I got the regulator replaced at my local Volvo dealership, which seemed to fix all the problems I had with the car except one. While my regulator was giving up, It was sending voltage to unnecessary parts that I did not need to use at the time. For example, my high beams came on by themselves, all the gauges inside the car brightened up, and so on and so forth. Eventually, my high beams went off, but I could never turn them back on. Also, once I received my car from the dealership, everything worked fine, except for my high beams which refuse to come on. The indicator light on the dashboard comes on, but the lights themselves don't. I wanted to check them myself to see if they were busted, but don't know how to get them out to examine them. Also, I don't know which fuse to check to see if they came on either. I just got this car in October of this year and had only had it for 36 days prior to the regulator going out, so I don't know the first thing about getting the high beam light bubs out. Sorry for the book of a story, but I just wanted to give all the whole story so that someone might be able to help me in the best way. Thanks.
Choguy03
Year and Model: S40, 2000
Post by Choguy03 »
There are two metal pieces that hold the bulbs. Remove the rubber cover on the back of the headlight and squeeze the two metal tabs together and pull them away from the front of the car. The fuses are easy to check. On the box under the hood, the inside cover has a picture with the positions. There is one fuse for each side I believe.
Sent from my BlackBerry 9810 using Tapatalk
dcarlson12
Year and Model: 1997 850 T5
Post by dcarlson12 »
I trust that you don't have fog lights which might be turned on? If you do, and they are turned 'on', then the high beams won't come on if I recall correctly.
See page 30 of the manual:
http://new.volvocars.com/ownersdocs/199 ... b.htm#pg30
Billc1015
Year and Model: 1994 855 turbo
Post by Billc1015 »
Its actually the other way around regarding the fog lights. If you have the fog lights on, when you hit the high beams the fog lights shut off. The fog lights will then come back on when you switch back to low beams.
I am here: http://maps.google.com/maps?ll=40.285153,-75.287838
BerniniCaCO3
Year and Model: V70XC / 2001
Post by BerniniCaCO3 »
a bad regulator/ excess voltage could certainly burn out your fuse/bulbs.
How'd those simple steps turn out; find a culprit?
cabooster
Post by cabooster »
Turns out my bulbs were burned, thanks for the help. Sorry for the lengthy response time, been swamped at work lately....
