S90 Oil leak around filter assembly
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
lindy8_man
Year and Model: 1998 S90
Post by lindy8_man »
Well, the 98 s90 is sitting at 221K and I have an oil leak I can't afford to ignore. So... I went hunting around, and found some hoses that needed to be replaced. They were flanged, and spongy. But these hoses bring coolent to what I presume is the oil pump housing. So, my search continues. I have attached some photos of the area. Has anyone run into this before?
Beer and DIY Volvo Repairs are proof that God loves us and wants us to be happy.
phils94850
Year and Model: 2009 s60 turbo
Post by phils94850 »
id say thats your oil cooler housing. Id replace the hoses, clean everything up and go from there.
1996 Platinum Edition
danr960
Year and Model: 964 1994
Post by danr960 »
The oil could be coming from the o rings that seal the oil cooler. That large nut has to be removed, but first confirm that is is leaking there and not from above, the front cams seals will drip down that far. You might try snug up that large nut to see if that stops it.
Replacing the orings is fairly easy.
DanR '94 964 360,000 miles (126,000 on the new engine)
njht2
Year and Model: volvo v90 1997
Post by njht2 »
Hi I had this problem.it was a leak from the oblong plate just above the filter assembly.the o ring seal was defective.hope this helps.regards njht5
njht2
Post by njht2 »
Hi I had a leak in that area,it turned out to be a leak from the rectangular cover above the filter.I replaced the o ring type seal which put the problem right.
