PO305- cylinder 5 misfire
jblackburn
Year and Model: 1998 S70 T5
Has thanked: 9 times
Been thanked: 19 times
Re: PO305- cylinder 5 misfire
Post by jblackburn »
http://www.fcpgroton.com/product-exec/p ... k+Plug+Set
$50. Totally overpriced if you ask me, but then my car is stock at 10 psi and I'm not sure how it would act with more power.
The coppers are $1.50 each and last ~30,000 miles before I go about changing them. I just don't really see the point for myself in throwing 10x that at spark plugs.
Cylinders are 1-5 across from the passenger side of the car.
'98 S70 T5
2016 Chevy Cruze Premier
s70glt novice[Will]
Year and Model: s70 glt 98
Post by s70glt novice[Will] »
Geez, that is a lot! Think the Bosch Super coppers would be okay? Worse comes to worse i wasted $10 and just switch them out.
Thanks for the info and help!
'98 s70 GLT-127k
ARD Green, obx, 16t, other go-fast parts
jblackburn
Worth a shot - it's less than the cost of 3 gallons of gas. I push my car pretty hard sometimes and I've had no problems. I took them out after 20,000 miles when I changed the timing belt, and they were barely worn at all.
I used to have Autolite Double Platinums, and while they ran OK (and got slightly better gas mileage - no lie - don't know why that is), it felt like my transmission was dying with the shift from 1st-2nd when it's at full power. When I switched back to the coppers, I found out it was definitely a misfire causing the jolt when it let off to change gears. Can't imagine it was good for the engine.
'98 S70 T5
s70glt novice[Will]
yea, seems i have a really bad one of those. i went down to the autoparts store and got some bosch super plus coppers with yttrium. It was the only coppers they had. hope they work
(for those who dont know, yttrium is a transitional metal thats chemically closer to the lanthanides)
'98 s70 GLT-127k
jblackburn
Think that's what I have.
Set the gap closer to .026" rather than .028"...should help with the elevated boost pressure.
'98 S70 T5
s70glt novice[Will]
thats what im thinking. thanks for the help. maybe rename the title to make it a little more specific in case anyone else has these troubles :)
'98 s70 GLT-127k
Roadrunner
Year and Model: 850 GLT 1993
Post by Roadrunner »
Late input but have you tried Denso U grove copper plugs? I use them and I am very pleased with them. For the spark plug wires get the lest rezentest (sp) type of good quilty. An OEM cap and rotor and use electricc greass to keep the corosion out of the plug wires connection. I am not sure about the HD coil for my car has the stock coil on it. Also check if their is a air leak in your intake tub from the air filter. This will cause the Air mass not to be reading right. Also if need be turn the distrubeter cap a small degree to increase RPM and this will end your miss.
1993 850 GLT 300,000 miles plus and still going.
s70glt novice[Will]
I think its my wires. the date said 97 36 D:
With the new plugs its not as bad, but it still happens. I'll try and order the new wires from FCP Groton soon.
Thanks for the input roadrunner, i saw those on the screen, but went with the boschs, mine do have a U grove in the rod.
'98 s70 GLT-127k
s70glt novice[Will]
I gapped the new plugs to .25 :oops: I'll get a new gapper and gap to .025
still runs great though. Volvo's are tough ;)
'98 s70 GLT-127k
jblackburn
.25"?!? I'm surprised it's not running like a tractor.
'98 S70 T5
