LOL, man you can't stop an oil leak with silicone. If you're taking about the turbo return line, there is a little kit you can buy to stop it. Easy fix they tell me.
http://www.ipdusa.com/products/5352/111 ... e-seal-kit
Oil leaks, but only while driving
- rspi
- Has thanked: 34 times
- Been thanked: 72 times
Contact rspi..
Re: Oil leaks, but only while driving
Thank you; yes: the turbo oil return line.
Let me ask: why's it leak in the first place? I'd think that the oil would just run right into the oil pan, even without a seal; even if the oil returns under pressure, it has the entire oil pan into which to run, right? Seems like it would have to "run uphill" and past the seal, in order to get outside.
Also, what could be used to supplement the seal, if not silicone?
Thanks for the input!
- Been thanked: 472 times
I had the exact same leak, but the Root Cause was the REAR Cam Seal, not the rectangular plate seals as mentioned by rspi.
Anyway, I updated the seal using Corteco seal ($6/each):
viewtopic.php?t=50752
- wizechatmgr
- Has thanked: 45 times
- Been thanked: 126 times
Any idea what those locations were purposed for that have blocking plates? Inquiring minds want to know...
- Has thanked: 1505 times
- Been thanked: 3818 times
Robert...can You post the part number for the block off plate seal kit?
I’m interested.
Wcm...my files Tell be that behind those plates are the toggle switches to enable the heated rear third seat option.
I’m interested.
- ZionXIX
- Has thanked: 65 times
- Been thanked: 194 times
I think i would like to have a look at those "Files".
