i have a b5234t turbo motor,is it a low pressure motor and if i put a high pressure turbo and upgrade on the motor will this work,or can i just put it on and it be okay....thanks
im also going to have twoafter market stage 1 cams put in it also,with a tune and exhaust ,also thinking on putting the snabbs big bore kit also....i have my money in and keeping the car....im getting it painted this week and putting new wheel and tires on also.
also going for other mods also.will keep you updated.
B5234T motor: low pressure or high?
trophytaker308
- Year and Model: 1995 850t turbo
Reason: Please title posts correctly, as you agreed to when you registered. Thank you.
1995 850t turbo,siver with black leahter interior (perfect),, 118000 miles .second owner.9 out of a 10...!
jblackburn
- Year and Model: 1998 S70 T5
- Has thanked: 9 times
- Been thanked: 19 times
A b5234t is a high-pressure turbo motor. 2.3L T5 engine.
'98 S70 T5
2016 Chevy Cruze Premier
trophytaker308
http://yhst-26451710505916.stores.yahoo ... ituca.html
will thes cams make that much of a diffference on my car and will they work?thanks again.
jblackburn
Those are for the old 80's redblock 4-cylinder engines.
A popular upgrade with the turbo motors is to put NA (non-turbo) cams in them.
'98 S70 T5
trophytaker308
is there ant after market stage one cames for the 850 series??
will it make much more difference to put the non t cam in ,my car??..thanks.
trophytaker308
i also found a 1997 850 t-5 in the junk yard with 50,000 miles.if i were to take the ecu out of it,will it work and will i notice a difference also...thanks again,sorry for so many questions at once,just thought i would ask will it was on my mind...thanks again.
trophytaker308
is there a thread were someone put a glt cam in there turbo volvo on hear that i can read about???thanks.
jblackburn
I'm confused. You already have a T5. The ECU is the same for every turbo model 850...whether it's called a T5 or a Turbo.
There's lots of good information from you here on a forum where they really mod their cars more than MVS people.
http://www.google.com/custom?hl=en&safe ... ospeed.com
'98 S70 T5
trophytaker308
ok i didnt know that.since the turbo (t-5) had 240hp and mine had 220 i thought that it might be the ecm,but i guess i was wrong...sorry.,
jblackburn
The 850 "R" models had 240 hp, yes...and that WAS just an ECU thing, along with a different exhaust manifold.
If you're looking for just more HP, the best steps would be:
-Exhaust
-NA Cams
-ECU tune (on your existing ECU)
I'd probably recommend an auxilary transmission cooler as well. Everyone tends to forget about the poor transmissions when they go looking to up power on their cars. There's several other "performance upgrade" tidbits you can add here and there, but I have no idea how great the power gains are. Probably very modest if anything. Those include things like a reverse intercooler setup, silicone hoses, cold air intake...
-Exhaust
-NA Cams
'98 S70 T5
- 3018 Views
Last post by Hoytster
- 11 Replies
- 4645 Views
Last post by Sommerfeldt
