850 windshield curve
itsnotavolevo
- Year and Model: 1995 volvo 850
just wondering if anyone knows why some 850s have curved windshields? if you own one you know what i mean, sometimes the drivers side wiper lifts off the glass and you have to bend the arm to get it to touch the glass. my 95 850 glt estate is like this, i don't mind it i was just couldn't find any info on why some are like this.
Billc1015
- Year and Model: 1994 855 turbo
It's not a curved windshield, it's a bent wiper arm. That is actually quite common on 850s.
I am here: http://tapatalk.com/map.php?vs5uog
- Has thanked: 312 times
- Been thanked: 818 times
You can either bend the arm or buy another one. Search the forums there are a lot of posts about it.
Jag91000
- Year and Model: 1994 850 Turbo Wagon
I had the same problem, i bent the arm slightly and it went back to the streaking again a week later, so i bought a new set of napa "curves" they come with an adapter that adds about 3/4"-1" of height to the wiper, the arm is now pushing more onto the windshield and it's much better.
itsnotavolevo
i have bent my wiper arm, but dont you think they would have thought about this when they were making the car?
jblackburn
- Year and Model: 1998 S70 T5
- Has thanked: 9 times
- Been thanked: 20 times
They changed it on the 1998 models to an arm that doesn't lose tension as much.
There are badly-designed things in just about anything you can buy. Nothing's 100% perfect.
'98 S70 T5
2016 Chevy Cruze Premier
viper69
- Year and Model: 850GLT 1995
- Has thanked: 77 times
- Been thanked: 2 times
jblackburn wrote:They changed it on the 1998 models to an arm that doesn't lose tension as much.
I have the same problem. Someone told me this on my post. I haven't considered doing the below, but I'm fed up w/defective wiper arms
"I haven't bought a new arm, but from what I've read there is a V70 version of the arm that is redesigned and stronger than the original one for the 850's"
Can someone confirm if BOTH pairs of wiper arms from a 1998 V70 fit on a 1995 850GLT sedan??
Here's my original post
https://www.matthewsvolvosite.com/forums ... =1&t=32464
Volvo 850 GLT 1995
5 Speed Manual transmission
122,500 miles and barely broken in
'82 Volvo DL Wagon, 4 speed manual
'77 Saab 99 EMS, 4 speed manual
I don't have a definitive answer to your question, except to agree the wiper arms were redesigned.
But FWIW, I have read postings where people said an x70 arm on an 850 "worked great for me" and others that said "the x70 arm just doesn't mount up right, it doesn't work."
- MoVolvos
- Been thanked: 525 times
https://www.amazon.com/Goodyear-GY-WB765 ... B002FWXRC4
When you say wiper arm do you include the metal part that holds the blades only. Just replaced mine with the ones above but from Costo at about half the price. They were out of the OE length so I grab the next length as I have always done (did forget though) with my other vehicles. An extra 1/2 inch on either end works great! They stay to the curvature of the windshield and do not make noise like some others when the rain is light. First saw this design on my brother's now cousin's 2003 P71 Crown Vic Interceptor purchased with 8 miles on it. They have improve it slightly since then.
No, that is the blade.
Arm = the piece that attaches to the splined shaft of the wiper motor.
Blade = the easily removable piece that holds the rubber "cleaner"
Refill = just the rubber piece, som blades you can replace just the refill as opposed to getting a new blade.
This post is about questions regarding the arm but yeah, you may be able to resolve the problem with a different blade.
- 994 Views
Last post by Cees Klumper
- 42 Replies
- 7056 Views
Last post by bmdubya1198
- 1462 Views
Last post by malcolm2
- 802 Views
Last post by Euroboy
- 3611 Views
Last post by jimmy57
