v 40 19 turbo deisel estate
1996 - 2004 S40
1996 - 2004 V40
mistley
Year and Model: 53p 19t v40 estate
Post by mistley »
when driving car will just cut out have to prime the priming pump to get it to start again also found split in turbo pipe replaced it but car not reving right and turbo is lacking qwite bad
regent
Year and Model: 2015 XC60 T5
Has thanked: 2 times
Been thanked: 12 times
Post by regent »
Welcome aboard, mistley.
Have you ruled out air getting into the fuel line; what is the condition of the filter?
Also, I am having trouble decyphering the Model Year of your turbo Diesel; could you specify that again?
Thanks
2015 BMW 335i
2015 XC60 T5 Premier Plus
2002 S60 2.4 n/a - retired :(
1987 340 DL - retired :(
mistley
Post by mistley »
regent 53 plate 19 deisel turbo estate
regent
Post by regent »
So, it is a 2003 V40 1.9 TD, correct?
2015 BMW 335i
regent
Post by regent »
Hi Mistley,
After you've ruled out fuel filter and air ingress into the fuel lines (this is vital for a Diesel), here is a suggested list of what to do next:
1. you want to clean the MAF sensor
2. check for vacuum leaks
3. inspect the PCV oil trap (or verify there is vacuum in the crankcase)
Please post back what you found.
Thanks
2015 BMW 335i
mistley
Post by mistley »
had sensor replaced today 150 pound before didnt hear turbo and had good boost low reeves now can hear turbo and no boost untill high up in the reeves so still not fixed thanks regent
