my driver side door hinge makes a loud popping sound
nomorwar
Year and Model:
Post by nomorwar »
how do I fix this?
Pauloil
Year and Model:
Post by Pauloil »
find some indy mechanic who can weld the hinge back onto the A frame
a good bodyshop or the dealer could also do it for more$
99 V70XC 158K
95 850glt 188K
nomorwar
Year and Model:
Post by nomorwar »
I can't figure out how to get to the part that needs to be welded as it appears to be inside door frame?
nomorwar
Year and Model:
Post by nomorwar »
sorry, thanks for info
MadeInJapan
Has thanked: 17 times
Been thanked: 35 times
Post by MadeInJapan »
Here, this might help you....avoid the welding...too many wires in there and it all has to come apart to do the job...this is much easier and good success as long as the check strap isn't totally broken in two:
http://au.geocities.com/ozbrick850/door-stay_fix.html
nomorwar
Year and Model:
Post by nomorwar »
pardon my ignorance, as I am not a mechanic, but how would one hold the nut tightly enough to attach the bolt properly and tight enough once it was in place? thanks
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2658 times
Been thanked: 1248 times
Post by matthew1 »
This happened on my '97 850, and I had it welded at a Volvo indie shop for a little over $100.
Also -> Amazon link
MadeInJapan
nomorwar wrote:pardon my ignorance, as I am not a mechanic, but how would one hold the nut tightly enough to attach the bolt properly and tight enough once it was in place? thanks
Tape on the end of your finger to start with and then a spanner bent to fit in and hold the nut at the same time with you holding the other end. I've read many posts on the Brickboard saying this method worked. You can weld if you want, but expect to pay high dollars.
