my driver side door hinge makes a loud popping sound
MadeInJapan
- Has thanked: 17 times
- Been thanked: 35 times
Here, this might help you....avoid the welding...too many wires in there and it all has to come apart to do the job...this is much easier and good success as long as the check strap isn't totally broken in two:
http://au.geocities.com/ozbrick850/door-stay_fix.html
- Has thanked: 2656 times
- Been thanked: 1248 times
This happened on my '97 850, and I had it welded at a Volvo indie shop for a little over $100.
MadeInJapan
Tape on the end of your finger to start with and then a spanner bent to fit in and hold the nut at the same time with you holding the other end. I've read many posts on the Brickboard saying this method worked. You can weld if you want, but expect to pay high dollars.nomorwar wrote:pardon my ignorance, as I am not a mechanic, but how would one hold the nut tightly enough to attach the bolt properly and tight enough once it was in place? thanks
