holler1 wrote:Probably the best (and only) way to find out is to try it and see, especially since it was already removed once. Didn't the shop drive it after removing the shaft to see if the noise was gone? If not, why did they remove it?Question # 2: Will this fix work for a bad angle gear or just for problems past angle gear? I ask this to be sure that removing the drive shaft will elliminate sound from bad angle gear and also stop any future damage to car.
The shop removed the drive shaft and replaced it with a new one because they thought the sound was coming from a bad drive shaft bearing. After replacing it I started to drive home and the sound was still there, they then did more investigation and came to the Angle Gear as the problem.
