I've been reading the ECU modification over on Volvospeed fix the CEL issues with the air pump. Just noticed that they introduce the topic mentioning the 1997 850. I have '96 850. Before I start messing with the ECU, just wanted to be sure this modification would also apply to the 1996 850 SAS system.
Thanks
850 SAS (Air Pump) Delete Modification
- Has thanked: 312 times
- Been thanked: 818 times
Yes.
On any 96 850 with an air pump, the "SAS delete" standard procedure will work. I used the Volvospeed writeup to do it on mine.
KlubMarcus
- Year and Model: V70 XC, 1998
I've done it on mine, over a week with with no CEL. Nothing removed, just disconnected the air pump wiring harness in front of the radiator. If someone sold me the car right now, I wouldn't even know the mod was done.
gmtgmt
- Year and Model: Volvo 850 T5R
I did this to a 95 960 2.5 that i converted to an early 3.0 from a 1991
removed the air pump and pluged the Valve and removed the relay in the fuse box for the airpump been driving for last mounth no problem. passed MOT with flying colors
KlubMarcus
Follow-up post. No more SAS check engine lights. No engine problems whatsoever. Best mod I have ever done to any car I have owned
mespalin
- Year and Model: 98 V70 T5; 96 850
Both my wife's 96 850 and my 98 V70 T5 have had this modification. No CEL, although the readiness cycles have yet to complete. But, took the 96 thru DEQ today, and asked if he could do an exhaust test instead of the usual OBDII and he agreed and it passed. I think for many cars if the drive cycles aren't complete, they won't pass a 96 or newer car with OBDII, but a Volvo they will. I am removing the SAS pumps from both my Volvos, never to worry about them again!
- 9 Replies
- 4497 Views
- 17 Replies
- 2673 Views
- 887 Views
Last post by misha
- 25 Replies
- 5960 Views
Last post by Gerd
- 872 Views
Last post by wapitiscat
