Rear Cam Seal
eddiecohoon
- Year and Model: 1998 C70 Turbo
Rear Cam Seal
Would a rear cam seal leak so that it would wrap behind the motor and get on the catalytic convertor?
jblackburn
- Year and Model: 1998 S70 T5
- Has thanked: 9 times
- Been thanked: 19 times
Absolutely. That thing's blown clean out.
I had oil dripping halfway down my car.
'98 S70 T5
2016 Chevy Cruze Premier
- rspi
- Has thanked: 34 times
- Been thanked: 72 times
Contact rspi..
eddiecohoon
Is there one rear cam seal or two
- Has thanked: 293 times
- Been thanked: 765 times
Each cam has one rear cam seal. There are two cams, so two rear cam seals.
One rear cam seal is under the distributor, the other rear cam seal is under the camshaft position sensor (the CPS).
If you install them yourself, make sure you don't push them in too far. When yo are all finished the cam seals are supposed to be flush with the outer mating surface, not recessed.
'06 S60 R, 197k
'07 XC70, willow green, 212k
'99 Camry V6
153k
'06 S60 R, 197k
'99 Camry V6
- 1296 Views
Last post by iRenaissanceMan
- 7874 Views
Last post by tyguyc
