removing radio without triggering code
I was going to remove the original head unit on my 98 XC but am afraid it will trigger the "code". Is there a way to avoid that problem? What triggers the need for the code input? Is it interuption of power for a certain amount of time?
- BEJinFbk
- Year and Model: '98 V70 R
- Has thanked: 93 times
- Been thanked: 146 times
Nope. If the radio loses power for any reason, it locks up.
You may already have it. Check for a radio code card in
the owner's manual folder or look on top of the radio.
Many owner's write it there to avoid losing it.
Even if you haven't got it, it's easy enough to get.
- MoVolvos
- Has thanked: 310 times
- Been thanked: 524 times
If you remove the battery it will also lock up. With older units the buttons can be sensitive so you can cause a 3 tries your out lock up. You will then be required to have your car ignition on so the unit is hot and powered on for 2 hours before it will allow you to try 3 more times with the code or take a 2 hour trip somewhere.
Blessing,
Blessing,
JRL
- Year and Model: Several
- Been thanked: 16 times
You can pull the radio out of the slot but the second you disconnect the power supply you will need the code
ONE SECOND is all it takes
Huh?For select boxes, checkboxes, and radio buttons, the event is fired immediately when the user makes a selection with the mouse, but for the other element types the event is deferred until the element loses focus.
2015.5 V60 T5 AWD Platinum
2012 XC60 T6
2012 S60 T6
2011 S40 T5
Gone but not forgotten:
2009 C30 R Design Sold to buy more Volvos
2007 S40 2.4 t-boned and totaled
2010 V50 2.4 hit a deer and totaled
2000 V70 SE head gasket
2000 S70 SE sold with 240,000
2012 XC60 T6
2012 S60 T6
2011 S40 T5
