Hoses to heater core 1994 940
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
jaashua
Year and Model: 1994 940
Post by jaashua »
My mechanic bypassed the heater core while I was determining if I wanted to junk or keep and repair my Volvo after the heater core cracked. I decided to keep it and replaced the heater core myself. The heater core is replaced but now I'm not sure which hoses run to which of the heater core nipples. Can anybody give me some direction? I'm very new to car repair, so I have no idea what is what, so I'll need more than the technical name for the location. Thanks. Here are two pictures of the area where I believe the bypass is.
MoVolvos
Has thanked: 312 times
Been thanked: 525 times
Post by MoVolvos »
If there is no control outside to restrict flow then it is continuous so hose placement should be matter? Temperature of Heat use is via Blend Door(s).
http://eeuroparts.com/Parts/PartDetail. ... Code=73642
jaashua
Post by jaashua »
I already replaced the heater core. I'm just trying to hook it back up to the hoses inside the engine, but I'm not sure which hoses because I didn't disconnect them.
MoVolvos
Post by MoVolvos »
BKM98 S70 T5 wrote:-
Sorry, there was a typo! I should have wrote hose placement should NOT matter if the coolant is continuously flowing through it whereas other Manufacturers there is a Valve that controls hot coolant from entering the Heater Core unless it is called for. In that case which hose goes where makes a difference.
jaashua
Post by jaashua »
Ah. Cool. Thank you very much. Only remaining question is which hoses do I connect? In the first picture I captured what I think is the bypass, but I'd like to be sure. Is there a way I can identify the two hoses I'm supposed to connect? Thanks again.
