1993 850 removing oil pan
brenthymer
- Year and Model:
i have an oil leak that looks like it's coming from the oil pan. the manual indicates i have to remove the engine from the car to remove the oil pan, is that correct? while underneath the car, it looks like I can just remove the pan, does someone know something i don't and, if so, are there any ideas on how to remove the pan without removing the engine?
White850Turbo
- Year and Model:
IIRC, the problem is that the power steering lines are in the way. If you can remove these, you should be able to access the pan w/ no problems.
-Sean
1995 850 Turbo (Extensively Modded)
1998 S70 T5 (Almost Stock)
