New How-To: Install Spark Plugs 850/S70/V70/C70
This topic is in the MVS Volvo Repair Database » Spark Plug Change Tutorial: Volvo 850, S70, V70, XC70, C70
paul_b
Year and Model: V70 2000
Re: New How-To: Install Spark Plugs 850/S70/V70/C70
Post by paul_b »
The tutorial is great, but I ran into a problem. My 2000 V70 has the rectangular coil, and does not have the nice thick single cable, but has several wires to each coil surrounded by a black plastic wire organizer. Unfortunately the wire organizer has degraded and breaks into small pieces at the lightest touch. So, I have factory installed 'crud' waiting to fall into the plug well and into the cylinder if the plug is out.
My approach, after noticing the bits, was to use a compressor to blow the crud off the top. Then for each plug blow out each well before removing the plug. Then carefully replace the plug. Also, after the first pass of blowing the crud off I noticed that the timing belt is exposed with the cover off, I was more careful after that. The plastic was so degraded that compressed air broke pieces off, there is very little remaining. It appeared that this was not a new problem. Last plug change was by a Volvo dealer, plug 4 had some corrosion like residue.
Status: after replacing the plugs and putting the covers back on the car started and ran well (for the 15 minutes I ran it).
Question: Any thoughts about the degraded wire organizers? Can I leave the wires loose? If replacing is necessary, any suggestions for better quality? They seem to be made from the same plastic as surround wire runs in the engine compartment. They plastic is just not up to the heat from contact with the engine block and no airflow under the cover.
My default is to leave it as is for now. Replace with new, automotive grade wire organizer in the near future. Buying new plug wires is not in the budget now.
Thanks, Paul
jblackburn
Year and Model: 1998 S70 T5
Has thanked: 9 times
Been thanked: 19 times
Post by jblackburn »
Mine is all degraded too on my injector wires.
I would suggest getting some heat shrink tubing and putting it around the wire bundles.
'98 S70 T5
2016 Chevy Cruze Premier
KlubMarcus
Year and Model: V70 XC, 1998
Post by KlubMarcus »
Some more pictures to supplemental earlier posts from a 1998 V70 XC spark plug change.
Volvo OEM spark plugs for turbo models, gapped 0.03" just like the manual says.
CIMG1736 (448x800).jpg (239.74 KiB) Viewed 2663 times
Dielectric grease and anti-seize lubricant for high temp applications.
CIMG1798 (448x800).jpg (186.5 KiB) Viewed 2663 times
Torque wrench, ratchet, small flat-blade screwdriver, flex-joint, ratchet extension, and spark plug socket.
CIMG1799 (448x800).jpg (207.32 KiB) Viewed 2663 times
There are plastic spark plug wire guides that come off by hand. This one unsnaps using a small flat-blade screwdriver.
CIMG1786 (800x448).jpg (195.11 KiB) Viewed 2663 times
This guide is marked 1-5 to correspond with the spark plug wires and helps keep the wires off the engine block.
CIMG1787 (800x448).jpg (142.68 KiB) Viewed 2663 times
Here are all the plastic guides taken off the spark plug wires.
CIMG1788 (448x800).jpg (150.51 KiB) Viewed 2663 times
Using the shop vac to suck out debris before removing the old spark plug. I also vacuum after removing the plug as a precaution.
CIMG1789 (448x800).jpg (267.1 KiB) Viewed 2663 times
Removing old spark plug at #1 cylinder using ratchet, extension, and flex-joint. Turn the spark plug socket slowly to avoid stripping threads.
CIMG1790 (448x800).jpg (244.05 KiB) Viewed 2663 times
This spark plug socket has a rubber insert that prevents the plug from dropping back into the hole.
CIMG1791 (448x800).jpg (225.02 KiB) Viewed 2663 times
Old and new spark plug side-by-side. This is after 25K miles, should've changed at 20k intervals instead.
CIMG1792 (448x800).jpg (169.49 KiB) Viewed 2663 times
Wipe anti-seize lubricant on threads only. Use a shop towel to wipe lubricant off the electrodes.
CIMG1794 (448x800).jpg (152.54 KiB) Viewed 2663 times
Place new lubricated spark plug onto socket and carefully thread into cylinder until snug.
CIMG1795 (448x800).jpg (159.69 KiB) Viewed 2663 times
Use torque wrench to tighten to 18.4 ft. lbs. +/- 3.7 ft. lbs. (I set it at 22).
CIMG1793 (800x448).jpg (261.15 KiB) Viewed 2663 times
Lubricate spark plug wire boot, especially on the interior where it will contact the white ceramic when inserted. Do not get any on the metal contact inside.
CIMG1796 (448x800).jpg (205.77 KiB) Viewed 2663 times
Spark plug gap gauge and old plugs lined up 1-5. The infamous #3 plug has the most carbon, probably because it's in the center and hottest part of engine.
CIMG1797 (800x448).jpg (199.72 KiB) Viewed 2663 times
:o The beater just won't die! So we're clawing our way back to Stage 0.
cartagena
Year and Model: v70 AWD 1998,
Post by cartagena »
I found that using E3 spark plugs provided a better oomph for my V70 compared to the other brands and no need to gap. Also it gave me an indication of what kind of shape the engine would be in when I replaced them. Spark plugs are like teeth, if they aren't clean its gonna be some expensive specialist work to bring it up to a shine again.
Volvo V70 AWD 1998
Volvo V70 XC AWD 1999
Mercedes 300E, 386XXX, 1990
geokilla
Year and Model: S70, 2000
Post by geokilla »
Do we need anti-seize lubricant? My spark plugs are long overdue and I don't have any anti-seize lubricants. I think I'm near 80k km on them. Have to double check to make sure.
2000 Volvo S70 SE; First Owner; 321km; Retired
2012 Volvo S60 T5 Level II; Gone
Has thanked: 1505 times
Been thanked: 3818 times
You can touch the threads to the dipstick to put a drop of oil in the threads and keep them from seizing up. Important if you are running the fancy plugs with 100,000 mile intervals
mecheng
Has thanked: 15 times
Been thanked: 21 times
Post by mecheng »
Always use some kind of lube when steel threads into aluminum or you will get galling. Oil is better than nothing but will likely dry up or get burnt off. Invest in anti seize and use on all service bolts and you will save yourself lots of headaches. It works by leaving small pieces of nickel or copper on the threads
1997 Volvo 850 GLT - 190km
Boost is my drug of choice
Ringo
Year and Model: 2006 70XC
Has thanked: 32 times
Post by Ringo »
How often do you folks replace your spark plugs if not experiencing misfires? Are there signs it's time?
What might do new plugs do for mileage or performance?
thanks, Steve
2006 XC70 2.5T auto (B5254T2) 125K 2nd owner
1999 V70 XC 2.4T auto (B5254T) 250K Trans failed 2018
1967 122S 2-door auto (B18B) 125K (ex-wife got it 1991)
I run Bosch copper plugs for 30k miles. I regap them at 15k. My turbo models usually need adjustment , my NA models do not. I get my replacememt plugs free from FCP
Ringo
Post by Ringo »
thanks for the quick reply Abacate.
Regarding Bosch copper for a turbo are you just solidly old school or cheap like me? Or do you not think the OEM Platinum are no better? I have a turbo XC70. Also what gap do you set and does it change and get larger (or smaller) ? I intend on buying from FCP - because I'm cheap! (but also because FCP are great folks)
