Folks - installed new headlight assembly, looks great. However the beam height is way too high. I see the adjustment screw behind the fixture but no matter which way I turn it, the beam does not adjust. Am I doing something wrong or is there something else to it?
For that matter, I notice the same behavior on the L/R adjusting wheel on the top of the fixture. Doesn't seem to do anything.
Thanks.
Headlight Adjustment
TipTopTommyT
- Year and Model: X/C V70 - 1998
- rspi
- Has thanked: 34 times
- Been thanked: 72 times
Contact rspi..
If you turn it they should adjust unless they are damaged.
Fish stick88
- Year and Model: 1994 - 850 Sedan
I can't remember where mine was messed up (because i had my dad fix it) but somewhere in there, one of the gears can pop out, did you buy a new (Volvo OEM) assembly or just an aftermarket?
Speed has never killed anyone, suddenly becoming stationary... That's what gets you.
'94 850 Sedan - 160k miles
TipTopTommyT
It's an aftermarket..,,looks like the other one adjusts. Another problem is that the rear adjuster pops off the back when the adjuster is being turned counterclockwise! Bizarre design. Was hoping to replace with original adjuster....tried removing it to no avail. Anyone know how to remove it or if it can be removed?
Got it from FCP -- OEM = $300....URO = $100.....but FCP swears by it. Oh well.
Fish stick88
Thats why OEM is most of the time 100% better. I hate getting parts that don't fit or aren't the right specs. Kills me.
- 1923 Views
Last post by arbop
- 12 Replies
- 2528 Views
Last post by volvoras
- 739 Views
Last post by SuperHerman
- 1211 Views
- 2704 Views
