Coolant Temp Sensor...
- rspi
- Has thanked: 34 times
- Been thanked: 72 times
Contact rspi..
Our's didn't work right after the car overheated just once. The new one worked good for 2 weeks but after I changed the head gasket it only worked for 2 days after that. I was thinking it was messing up because it was burping air but it stayed bad for a week then caused our battery issue.
jimmy57
- Has thanked: 5 times
- Been thanked: 322 times
Connector.cn90 wrote:Interesting! I still have the original ECT and car runs fine at 120K miles.
Question: is this a problem with the ECT itself or the Connector?
Usually occurs due to it being unplugged or any work in that area where the connector could be disturbed.
I suppose road salt spray could give you issues if the plastic disintegrated and fell off with time.
JimBee
- Has thanked: 33 times
- Been thanked: 43 times
When I went through the 850 connections prior to a trip last summer I struggled to get that one apart. When I finally succeeded it was obviously corroded, so I took my dremel tool with a tiny wire brush to clean it up as well as possible, then a pick with a barb on the end to scratch the insides of the tubes, before putting it back together with some dielectric grease. I've pulled a couple from wrecks and they always seem corroded. If that happens to mine again, I might just cut the pigtail and put in some new connectors that are more protected from the elements.
- Has thanked: 311 times
- Been thanked: 818 times
Do some reading, you will find the aftermarket ECTs are notorious for failing. I consider this a dealer-only (or junkyard-only) item.
- Been thanked: 504 times
Hmmmm,
If this is truly a connector problem, why does every thread in this Matthew Volvo forum and Volvospeed forum recommends people change their ECT when they replace the thermostat???
To me, it makes more sense to inspect/clean/lubricate the connector?
You're not reading the posts cn90, don't be fooled by this one thread - the connector can be a problem and should be checked, but more frequently the sensor itself is bad, e.g. wires falling apart, internal connections bad.
If the connector was usually the problem, then replacing the ECT wouldn't usually fix it.
Not to thread jack, but.......
I had issues today after replacing the alt yesterday. I know the CTS was unplugged/moved around alot. Other than an intermittant error code that I have had a few times since I've had the car, this is the first time that its given me any issues. I'll try this and order one tonight.
Thanks for the info
Thanks for the info
loveMy850
- Year and Model: 1994 850 WAGON
- Has thanked: 97 times
- Been thanked: 4 times
when first thing in the morning car starts fine, then after that its kinda hard starting, Ive changed the fuel pump, filter, got all vav. leaks that I could find, cleaned my maff sensor, whats the proplem anyone!
rguzz
- Year and Model: 1996 850 turbo
- Been thanked: 25 times
The connector can be found @ the dealer. Problem is you need to wire it in, and getting your big fat hands in there means removing upper rad hose +- power steering hose. If you wire a new one in, give yourself extra length so you can route as far from the intake as possible (theoretically to a less hot space).
