Need photo of fuel pressure regulator on fuel rail
ClayBubb
Year and Model: 850, 1997 non-turbo
Post by ClayBubb »
So I know what I'm looking for. (Sorry--I'm used to 50s - 70s American V8s. I'm an abject rookie on the Volvo here. Thanks for your patience!!)
j_cd
Year and Model: 1998 S70 GLT
Post by j_cd »
Fuel Pressure Dampener
I was just wondering if I should replace this about 20 minutes ago. I'm sending my injectors out for a professional cleaning.
jimmy57
Has thanked: 5 times
Been thanked: 322 times
Post by jimmy57 »
That is a fuel pressure damper. They look very similar but this is towards the middle and has no lines on it. It is simply a diaphragm chamber that stabilizes fuel pressure peaks and dips as injectors open/close.
I do not have a car here to take a photo of but your FPR is in a similar place on the fuel rail . It will have a vacuum line attached.
Found a photo:
j_cd
Post by j_cd »
Yeah I was wondering if the NA engine had something different on the fuel rail. Guess so.
ClayBubb
Post by ClayBubb »
Wow! You guys are awesome. Heck, I just barely got back from walking the bulldog, and here are all these pics already!! Back in a jiff, soon as I figure out the P0172 code.
ClayBubb
Post by ClayBubb »
PS, my non-turbo 850 only has the aforementioned fuel pressure damper. If that were it, it would truly be a booger to yank off a vac tube & put it back on!!
j_cd
Post by j_cd »
ClayBubb wrote:PS, my non-turbo 850 only has the aforementioned fuel pressure damper. If that were it, it would truly be a booger to yank off a vac tube & put it back on!!
I think you're saying your engine has the same part as mine. This one doesn't have a vacuum line going to it. I thought the pressure damper just unscrewed from the fuel rail, but I just tried, and it didn't.
jimmy57
Post by jimmy57 »
I didn't think 97 n/a's had it relocated.
Look down behind engine on passenger side, it must be in the line there.
The 97 GLT's had it there and a damper usually is used on remote FPR applications due to hydraulic ugly stuff a long column of fuel causes.
Amys 940
Year and Model: 940, 1994
Post by Amys 940 »
Yeah, my 98 V70XC has the regulator down near the steering rack on the passenger side. Odd location if you ask me.
jimmy57
Post by jimmy57 »
Fuel heating is a bad guy for hydrocarbon emissions. Hot fuel evaporates too much and exceeds the capacity of a reasonable sized charcoal canister. Not recirculating fuel from rail was the first effort, second was moving FPR back by fuel tank, the final one is controlling fuel pump speed to keep the pressure controlled.
