If I start my glt and let it warm up in place for more than 5 min the transmission arrow begins to flash and the car locks in gear. The next time I drive it the car functions properly, however the light remains flashing. The next time the light goes out and all is well. I have tried this a number of times and verified this sequence. All this seems to have developed after a tranny flush.It was done by my regular mechanic and re checked afterwards.
any ideas?
93 850 glt transmission issue Topic is solved
uest
Oh come on, someone has to have a thought or theory. I'm out of ideas on this one.......Iam worried about getting stuck this winter... Should I be concerned?
- Tsquared
- Year and Model: 11 C30
Get the code pulled from the computer. That will tell you where to start. The flashing light is a trans problem - sorry. Do a search on the "arrow" or "transmission" and check out the threads on other trans issues.
I replaced my trans about 2k ago. I wnt through multiple flushes in hopes of flushing the problem away.
Good Luck.
Good Luck.
'11 C30 T5
'96 854 - died an early death with 184K miles. Killed by the front end of an LTD on a suicide mission (T-boned and both cars totaled).
Guest
if this developed after tranny flush, u need to check fluid level and its possible bubbles could have formed inside, fill it up to the top hot mark when hot (check when temp at 3 o clock)
- Has thanked: 2660 times
- Been thanked: 1248 times
Might be PNP switch:
http://www.volvospeed.com/Repair/pnpswitch.htm
- 16 Replies
- 1769 Views
Last post by MoVolvos
- 670 Views
Last post by avianatalia
